March 21, 2011, 09:41 |
Remeshing with User Defined Options
Christian F
Rep Power: 15 |
I want to calculate the flow in a rotary piston engine (for expanding gases). thats for I got to use the Remeshing option in ANSYS CFX. In CFX Pre there are two possibilitys for Remeshing: 1. Remeshing with ICEM CFD this is not possible thince the movement is a rotating one (in the manuel it is explained that only translational moments are supported and in first tests it seems to be true) 2. Remeshing with User Defined options In this option I got to do the different meshes in front of the calculation. In CFX Pre i've got to tell the programm where are the meshes and when to use which mesh. so does anyone have a example for the second option since I don't know how the scripting files have to look like. thank you for your help Christian (TU Dresden) |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
User defined remeshing vs ICEM CFD replay remeshing | vmlxb6 | CFX | 0 | October 18, 2010 01:58 |
user defined turbulence model | manuutin | STAR-CD | 5 | October 14, 2009 05:29 |
Gradient of a User defined Variable | Ramadas | CFX | 2 | August 21, 2007 09:19 |
User Defined Scalars - Returning Values | Carlos V. | FLUENT | 0 | April 19, 2006 18:18 |
