Specific heat capacity zero pressure 4th order polynomial for air
Old   October 2, 2014, 21:24
Default Specific heat capacity zero pressure 4th order polynomial for air
badboyz31 is on a distinguished road
Hello there, recently I tried to create a model of air based on several data I gathered from the net. But I was unable to find the coefficients for the 4th order polynomial for specific heat capacity.
I tried to enter coefficients based on curve fitting that I did to a table of Cp vs temperature and it turns out that the specific heat ratio in the solver is almost equal to 1 with STP boundary conditions, so I guess that I may have entered the wrong coefficients.
Does someone here actually have the coefficients ? Or where could I find it ?
Thanks in advance.
badboyz31 is offline   Reply With Quote
Old   October 3, 2014, 09:40
Erik
evcelica is on a distinguished road
You have to divide by the gas constant. You also use Cp0 (zero pressure) not Cp.
See the documentation for more details.
evcelica is offline   Reply With Quote
Old   October 5, 2014, 20:11
Alright I'm gonna give it a try.
Polynomial coefficients for specific heat of Ideal gas avi031 Main CFD Forum 0 November 11, 2011 00:28
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
Cn specific heat capacity changes with Temperatur? lightgas CFX 4 July 7, 2006 06:51
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
