October 9, 2014, 16:06 |
non newtonian viscosity
mina
Rep Power: 12 |
Hi
To calculate the average velocity of ostwald de waele fluid flow at Re=50 as an inlet boundary, i need to write an expression for its viscosity first. can anybody help me to write this according m,n,max & min shear strain rate? is it possible? thanks |
October 9, 2014, 17:58 |
Rep Power: 143 |
If you know the viscosity function and parameters then why can't you calculate the viscosity?
October 10, 2014, 01:34 |
mina
Rep Power: 12 |
Because of shear strain rate. In ostwald fluid we define max & min for shear strain rate so we have a span for it not a constant value.
October 10, 2014, 01:40 |
Rep Power: 143 |
You can access the shear strain rate variable in CFX, then you could use this in your calculation. This would make the boundary condition a function of the flow domain but often this sort of coupling works OK.
Alternately you could just estimate the SSR, maybe from a simple pipe flow or something with a simpler answer. |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 06:00 |
Ratio of eddy viscosity to molecular viscosity : Laminar or turbulent flow? | JuPa | CFX | 7 | September 9, 2013 07:45 |
Non newtonian viscosity UDF -Diveregence in AMG Solver error | Josyula | Fluent UDF and Scheme Programming | 4 | March 19, 2013 00:05 |
non newtonian viscosity problem | moloykb | FLUENT | 4 | July 5, 2012 15:47 |
Too low temperature at combustor outlet | romekr | FLUENT | 2 | February 6, 2012 10:02 |
