Peekca Error
Old   November 4, 2014, 03:28
Default Peekca Error
Mansoor Saleem
Saleeman1234 is on a distinguished road
Hello
I want to insert an expression for thermal contact resistance
TCR= Constant * Temeprature
this temperature is not available on both side
so I get this error
" the Physics setup on domain interface "Plate" contains an expression that refers to a variable that is not available on both sides of the interface. this is not allowed. correct the problem, perhaps by using callback functions that refer to one side only."
Can you please guide me how can I call the function by one side only?
As I know the heat Flow side I can ignore the other side. but I dont know how?
Thanks in Advance
Saleeman1234 is offline   Reply With Quote
Old   November 4, 2014, 04:39
Mansoor Saleem
if I try by making an additional variable I get this error
Error detected by routine PEEKCS
CDANAM = /FLOW/GETVAR/PHYS_ZONE_DIR /SL3 /AV6 /CELAVMAP
CRESLT = NONE
Current Directory : /FLOW/PHYSICS/ZIF3/HEATM/RESIST
| Writing crash recovery file |
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Stopped in routine MEMERR
thermalcontactresistance
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 20:30
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
