Marcin
Rep Power: 13 ![]() |
Hello everyone,
I have to make a moving pipe into fluid domain. Can anyone help how to model this problem. Do you have any tutorials which will help to make this problem? Visualisation of this problem is on attachment. Best regards |
Rep Power: 143 ![]() ![]() ![]() ![]() |
Why are you modelling the pipe? This sounds like a simple moving mesh simulation.
Marcin
I need to simulate heat transfer on moving pipe . I must make boolean operation (substract) on fluid domain to make interfaces between pipe and fluid domain ??On the sources I define a move of the pipe ? This is my first time to simulite moving parts in cfx. Earlier I only simulate immersed solid
Have You any tutorials or any links for similar simulations ? Best regards |
CFX comes with a number of tutorial examples on moving mesh.
In this case I would start with just a moving mesh simulation of the fluid domain to get that motion working and the flow correct. Once that is working then add the solid domain and its motion. Note that this simulation will only work on CFX V15. You need to have motion in a solid to do this and V15 was the first version to support this. |
Marcin
hello Glen
Can You give me a title of moving mesh tutorial which I could start first Sorry for my poor english Best regards |
"Modeling a Ball Check Valve using Mesh Deformation and the CFX Rigid Body Solver"
"Oscillating Plate with Two-Way Fluid-Structure Interaction" "Modeling a Gear Pump using an Immersed Solid" (This one is actually immersed solids but is very useful to know as an alternate approach) "Modeling a Buoy using the CFX Rigid Body Solver" |
Marcin
Hello Glenn,
I have another question for this problem. This tutorials which You wrote on the last post are for immersed moving parts. All these parts on t = 0 s are on the fluid. On my problem on t= 0 s pipe haven't got any connection with fluid. I define velocity on pipe 0.2 m/s and on the next delta t pipe going into fluid. How to define connections between these two domains? I need to make cooling process for this moving pipe on the fluid domain. Do i must make a boolean operation on fluid domain (substract area equal of pipe diameter)? Best regards |
#8 | |
#9 |
Marcin
I know Glenn,
I wanted to say that on the all of these tutorials on time (for example) t = 0 s or on initial boundary conditions (steady state) all moving parts are on fluid domain. In my case pipe on time t = 0 s hasn't got any contact with fluid domain. Best regards |
#10 |
When the tube advances into the domain does it stop somewhere or does it go until it hits the other wall?
#11 |
Marcin
Pipe passes through the entire domain . There are no collision on pipe way.
#12 |
Your image shows a wall which the pipe will hit eventually. Does the pipe pass through this wall? Or is the far wall a long way away? Can you post some images of what you expect the pipe to do.
This is important as it will affect the way you model this. |
#13 |
Marcin
I post below explanation of my problem
#14 |
OK, thanks for the clarification. The way to model this is obvious now. Have a look at the quick drawing I have done.
Put the tube in a solid domain (domain 1). Put the tube inside a long cylinder, long enough to enclose the entire motion of the tube (this is domain 2). And cut a tube out of the box for domain 2 to slide through (this is domain 3). Domain 3 is a fluid domain, stationary mesh with a transient rotor stator GGI interface. Domain 2 is a fluid domain, moving mesh with a TRS GGI to domain 3 and a static solid/fluid GGI to domain 1. Domain 3 is a moving mesh solid domain with a static solid/fluid GGI to domain 2. Then move the mesh of domain 2 and 3 to generate the translational motion of the tube. |
#15 |
Marcin
pipe is empty inside. This is not a tube, this is a pipe
will there be a difference if this is a pipe ?? Below is a schematic cross section of pipe . |
#16 |
That does not change anything. Just means the solid domain is a tube and the translating fluid domain (2) has a bit which includes the inside of the tube.
#17 |
Marcin
Thanks a lot Glenn,
I try your method and reply ASAP Best regards from Poland |
#18 | |
Marcin
Can You describe in more detail ? Best regards |
#19 |
Which bit don't you understand?
#20 |
Marcin
1 ) on frame change/mixing model (on interface) i choose option transient rotor stator.?
2) domain 2 (on Your drawing) is moving domain ? 3) domain 1 and 3 are stationary domains? 4) solid domain have a defined solid motion on solid models option? 5) which domains have turn on mesh deformation? 6) on the interface (on fluid domain) which options i need to define ?? Best regards |
cfx, mesh deformation, solid motion |
simple open ended pipe flow with moving piston | lmarf88 | ANSYS | 1 | November 22, 2013 21:12 |
moving sphere in a pipe | sajeesh | FLUENT | 1 | February 25, 2013 08:35 |
Help needed in modelling/meshing a body moving in a pipe which is driven by a fluid | hareshram.n | ANSYS | 0 | March 19, 2010 02:23 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
