January 14, 2015, 20:49 |
velocity calculation in two phase flow
Sharon Wilcox
Rep Power: 11 |
Hi guys:
I have a question on two phase flow modelling. The issue is how do you calculate the velocity and momentum for a phase in a homogeneous flow simulation (mass weighted or volume weighted)? Thanks |
January 15, 2015, 04:48 |
Matthias Voß
Rep Power: 20 |
Since it is homogeneous--- both phases have the same velocity. If you want to extract the superficial properties... afaik they are calculated from the "alpha"- so they are "volume weighted". Correct me if i am wrong!!
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Flow/ Velocity Calculation | Nikunj.R | OpenFOAM Post-Processing | 1 | November 21, 2012 18:19 |
Velocity of flow v time | MitsubishiEvo6 | FLUENT | 0 | August 30, 2012 23:51 |
LES on two phase flow | Li Yang | Main CFD Forum | 0 | May 12, 2004 08:10 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
