how to calculate water average velocity in free surface models
Old   January 17, 2015, 10:23
Question how to calculate water average velocity in free surface models
hmasenger's Avatar
hamed
hmasenger is on a distinguished road
Hi dear friends
i am modeling water flow over an spillway by a free surface model.the problem is that i don't know how to calculate average water velocity just in water phase .i thing CFX calculates a wrong value while using "average water velocity@outlet"
i think cfx considers velocity in whole outlet surface but i need it to be calculated on only water phase.
one more question:
does any one knows how can i calculate water depth in free surface model? i mean i know how to use an iso surface at VOF=0.5 and then making Poly line by intersections an then plotting Y at that poly line , but can you suggest me an expression to subtract bottom elevation from water surface elevation?
best regards
hmasenger is offline   Reply With Quote
Old   January 17, 2015, 12:33
JuPa's Avatar
Mr CFD
JuPa is on a distinguished road
You want water superficial velocity.
Regarding your other question, try:
1) Create a plane in the x-y position.
2) Create an Isoclip on the plane, and select air volume fraction > 0. It will then show a plane of air without water, which you can then use to do contours etc.
JuPa is offline   Reply With Quote
Old   January 17, 2015, 12:36
hmasenger's Avatar
hamed
Yup.
I also used superfacial velocity but still it turns a wrong value for avarage velocity.
I think the problem is with water section area.cfx usex whole area to calculate avg but it should only considers water depth
Old   January 17, 2015, 12:37
hmasenger's Avatar
hamed
How can I force that to cfx?
Old   January 17, 2015, 13:05
JuPa's Avatar
Mr CFD
Originally Posted by hmasenger View Post
Yup.
How are you working out the average superficial velocity? And where do you want to calculate the average?
Old   January 17, 2015, 13:07
hmasenger's Avatar
hamed
I call the calculator and use predefined expression" avg(water superfacial velocity )@outlet
Old   January 17, 2015, 13:09
hmasenger's Avatar
hamed
As u see the outlet contains about 30% water and remain is for air
Old   January 17, 2015, 13:17
JuPa's Avatar
Mr CFD
Don't use the arithmatic average. Use the area weighted average, i.e.:
areaAve(Water.superficial velocity)@outlet
Old   January 17, 2015, 13:36
hmasenger's Avatar
hamed
I have already tried that. Nopp the problem still exists .
Old   January 17, 2015, 13:44
JuPa's Avatar
Mr CFD
What is the problem when you do areaAve(Water.superficial velocity)@outlet?
Old   January 17, 2015, 13:48
hmasenger's Avatar
hamed
Still The average is less than the value that should be! because it considers the whole area of outlet.
Old   January 17, 2015, 14:32
JuPa's Avatar
Mr CFD
I don't agree. Area average is a weighted average. If there is no water superficial velocity in some part of an area then its weighted average in that area is zero.
Try this, and if you still don't get the required answer then your results are wrong.
1) Create a new plane on the outlet.
2) Create a new iso clip, and set its location on the plane you just created.
3) In the iso clip, set the water volume fraction to be visable when it is >= 0.1.
4) Go to calculators and determine what the areaAve(Water.superficialvelocity)@iso clip is
Old   January 17, 2015, 14:35
hmasenger's Avatar
hamed
Thanx for the clue.I will inform you about the results
Old   January 17, 2015, 14:42
hmasenger's Avatar
hamed
That worked ricochet.problem solved.!! .that was exactly what I need.tnx alot
Old   January 17, 2015, 17:58
JuPa's Avatar
Mr CFD
Good!! :-)
Old   September 20, 2018, 02:09
subhankar das
subhankarnits is on a distinguished road
Hi @hmasenger what is size of elements you had taken for capturing sharp interface between water and air?
subhankarnits is offline   Reply With Quote
Old   September 20, 2018, 02:18
You will find that for most free surface applications CFX smears the free surface over about 4 elements. To get this it needs to be well converged and with good time accuracy. This means that the sharpness of the free surface is simply proportional to the mesh size - so finer mesh equals sharper resolution.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   September 20, 2018, 02:31
subhankar das
In my project the main aim is to capture water surface height and outlet discharge. There is no need of boundary layer velocity profile etc. But I heard that for some turbulence model results are largely depends on y+ value. So should I check for y+ value or just finer mesh near the free surface will do my job?
Old   September 20, 2018, 09:42
Opaque will become famous soon enough
Careful. The free surface is not a wall.
You may be sharpening the free surface resolution, but there is no influence on the yplus since it is not a wall.
Opaque is offline   Reply With Quote
Old   September 20, 2018, 09:45
subhankar das
Yes I know that. But channel bed is wall so there should I check y+ ?
[OpenFOAM] Multiphase 3D free wave surface post-processing visualization in paraview keepfit ParaView 26 February 25, 2015 09:59
how to calculate forces on the wall with free surface? phsieh2005 Main CFD Forum 2 July 13, 2010 08:11
Free surface water wave profile John N. FLUENT 0 February 2, 2009 16:17
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
