Commands for Double Precision
Like Tree1Likes
  • 1 Post By Lance
Old   March 20, 2015, 04:31
Default Commands for Double Precision
Stabum's Avatar
Stabum is on a distinguished road
I'm trying to simulate a waterjet propulsion system (with an axial turbo pump and a "S" shaped duct upstream). I firstly adopted a robust convergence approach (Autotimescale, Lenght Scale Option = Conservative, Timescale Factor = 1). After 10 hrs computing I reached 1E-4 RMS with MAX Residuals 2 or 3 orders of magnitude higher.
I changed the Timescale control to Physical Timescale, with an avagage residence time = 0.15 s. No improvements. I increased it to 1.5 s. Nothing has really changed. I would try the "double precision" option but since I'm running these simulatons with a university cluster, I don't know which commands I should add to the .pbs file to activate this option and to start the new simulation from the old one (in order to use the data of the previous one).
Nobody has any idea about what to do.
Please, is there anybody able to help me? Thank so much and... excuse my terrible english.
Below I add the script I've been using so far.
#!/bin/bash -l
#PBS -N FolderName
#PBS -l nodes=1pn=16:NRM
#PBS -l walltime=999:00:00
cd $PBS_O_WORKDIR
cat $PBS_NODEFILE | sort > pnodes
export NCPUS=`cat pnodes | wc -l`
ANSYSLMD_LICENSE_FILE=****@***.***.***.***
export ANSYSLMD_LICENSE_FILE
ANSYSLI_SERVERS=****@***.***.***.***
export ANSYSLI_SERVERS
/opt/shared/ansys/v145/CFX/bin/cfx5solve -def CFX_02_1.def -par-local -partition 8 >> log.txt
Thanks again
Stabum is offline   Reply With Quote
Old   March 20, 2015, 04:42
Lance
Lance is on a distinguished road
/opt/shared/ansys/v145/CFX/bin/cfx5solve -def CFX_02_1.def -double -initial-file myresultsfile.res -par-local -partition 8 >> log.txt
if you want to use the results file as initial conditons, or
/opt/shared/ansys/v145/CFX/bin/cfx5solve -def CFX_02_1.def -double -continue-from-file myresultsfile.res -par-local -partition 8 >> log.txt
if you want to continue the simulation.
latermary likes this.
Lance is offline   Reply With Quote
Old   March 20, 2015, 04:54
Stabum's Avatar
You're so kind! Thanks thanks so much!
[ANSYS Meshing] ICEM output precision papis ANSYS Meshing & Geometry 4 July 9, 2013 09:54
Number of elements x double precision matheusguzella ANSYS Meshing & Geometry 2 October 7, 2009 10:15
OpenFOAM14 for Mac OSX Darwin 104 gschaider OpenFOAM Installation 118 July 20, 2008 05:19
what's wrong about my code for 2d burgers equation morxio Main CFD Forum 3 April 27, 2007 10:38
double precision assigning in FRTRAN R.A.Khurram Main CFD Forum 12 October 2, 2001 11:00
