March 26, 2015, 13:50 |
Inlet PT different from BC
Brian
Rep Power: 11 |
I'm running CFX analyses of a centrifugal diffuser, with PT/velocity direction inlet and PS exit BC's. The baseline ran with no issues, but two redesign attempts (very similar grid, same boundary conditions) do not seem to be running correctly. The inlet total pressure is varying as much as 10% from the BC, and the mass flow is only a tenth of the baseline. Has anyone experienced anything like this? |
March 26, 2015, 16:50 |
Rep Power: 143 |
Sounds like a FAQ: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
Unless you have checked the convergence, mesh and time step size is suitable for your simulation then you have no idea if your results are accurate or not. |
setting the correct format of nonuniform List<vector> for inlet in 0 Folder | cfdonline2mohsen | OpenFOAM Running, Solving & CFD | 8 | July 18, 2019 08:03 |
multiple inlet as one inlet | amin_gls | CFX | 2 | October 2, 2013 08:59 |
velocity inlet and ideal gas simultaneously-what's wrong? | preetam69 | FLUENT | 0 | September 28, 2013 04:51 |
Inlet Velocity in CFX | aeroman | CFX | 12 | August 6, 2009 18:42 |
Diffusion component at inlet | Balaji | FLUENT | 2 | August 8, 2005 07:37 |
