CFD-Post: streamline movement from stat. to rot. part
Old   April 17, 2015, 06:30
Default CFD-Post: streamline movement from stat. to rot. part
**Anny** is on a distinguished road
Hey everyone,
I am trying to simulate the flow in a centrifugal pump.
Doing some test runs I recognized an abrupt cut in the "movement" of the streamlines between the rotating parts and the stationair parts like there is a missing interaction between the moving and rotating parts. The pictures attached should make it clear. Do I have to work it out in CFD Post or before in CFX Pre?
Thank you all very much for your time... again!
**Anny** is offline   Reply With Quote
Old   April 17, 2015, 06:31
The picture of the streamlines
Old   April 17, 2015, 08:21
Bruno
brunoc is on a distinguished road
You're getting the correct behavior.
The abrupt change in the streamlines is due to the fact that CFX (and most CFD software, in fact) solves the momentum equations on rotating domains using the rotating reference frame. The result is that the velocity vector inside the rotating domain does not have the \omega R component in its circumferential component.
If you want to plot the velocity field on the stationary reference frame, use Velocity in Stn Frame.
That's all in the documentation.
Cheers
brunoc is offline   Reply With Quote
Old   April 17, 2015, 09:33
Thank you very much for the explanation Bruno! I didnt thourd of the missing circumferential component in the stationary parts! ... I am going to search/ read now more about adding cyldrical coordinates to not symmetric parts and using turbo.
I apologie in advance for might having to ask some questions about it later
Cheers
specific heat capacity at constant pressure in CFD Post newbie384 CFX 5 November 27, 2015 21:25
Plotting Radial Velocity and Tangential Velocity in CFD Post ashtonJ CFX 5 July 13, 2015 02:49
Plotting the Viscosity Contour in CFD Post ashtonJ FLUENT 3 June 2, 2015 12:06
CFD Post Streamlines better representation? Dr. Flow Squad CFX 2 January 20, 2014 13:48
Chart of velocity on a streamline cfd post Felipe Mendes CFX 2 June 12, 2012 07:49
