June 3, 2015, 23:52 |
Mesh independent study
Govindaraju
Rep Power: 17 |
Dear all
I have a question on the following statement "A mesh independent study was performed by varying number of elements and I compare the velocity values at different points and the computed velocity values differed by less than 0.3%." But I heard from one of my friend's that this is not the scale to check the accuracy of the result (or) independency of the mesh elements. I ask the cfd expert here what is the answer for this? |
June 4, 2015, 03:44 |
Thomas MADELEINE
Rep Power: 11 |
depending on the case you study.
For me a mesh independence study should focus more on thing that are hard to catch with a coarse mesh (boundary layer, thermal transfer, etc) and so in macro value that are affected by this (Total Pressure drop, maximal massFlow in a nozzle, drag or lift force on blade). If you only want the velocity in the middle of nowhere, a quite coarse mesh is perfectly able to suit you. that's only my point of view, maybe other people here have different one |
June 4, 2015, 04:11 |
Rep Power: 143 |
Thomas is correct. If you only need to know the velocity in the middle of the flow you can get that with a coarse mesh, so there is no need to go fine. But if you want accurate heat transfer on a surface you will need to be very careful with your mesh.
That is why mesh sensitivity is not only dependent on what type of flow you are modelling but also what sort of result you are trying to get and how accurate you want them. |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[ICEM] (New to CFD) How to do a mesh refinement study w/ Fluent? | JAviles | ANSYS Meshing & Geometry | 1 | June 25, 2014 12:09 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
Mesh motion independent mesh regions | philippose | OpenFOAM Running, Solving & CFD | 12 | August 5, 2008 16:16 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
