February 25, 2010, 03:09 |
Fluids from two Inlets opposing each other
Arvind
Rep Power: 17 |
Hello Every1,
I am trying to run a simulation in which i have a domain as shown in figure. Through Inlet1 i have given velocity( from left to right) and through Inlet2 i want the same fluid to come in the opposite direction(i.e from right to left) but with different velocity. I gave negative values of velocity at Inlet2 thinking it shud work but the solver is terminating with errors. Pls can any1 tel whether I am heading towards the right direction. Last edited by Arvind; February 25, 2010 at 03:12. Reason: Mistake in title |
February 25, 2010, 04:58 |
Rep Power: 17 |
An inlet with negative velocity imposed on it is an outlet. Impose positive values with a direction normal to the boundary. Tijmus |
February 25, 2010, 05:19 |
#3 | |
Ciro Cannavacciuolo
Rep Power: 17 |
if you set "normal velocity component" on inlet2 the flux will go automatically from right to left, in your case. CFX knows that from Inlet BC the flux enters into the domain. A negative component is not raccomanded. |
February 25, 2010, 06:10 |
Arvind
Rep Power: 17 |
@ Timon and Mach000
First of all let me thank u for ur reply.......I tried setting normal speed B.C at inlet 2 (using positive value of velocity) but still the solver is terminated with errors after around 10-15 iterations. Is there any other thing that i am missing out??????? |
February 25, 2010, 06:23 |
Ciro Cannavacciuolo
Rep Power: 17 |
i suppose yuo have an "overflow".
Is the simulation transient or stationary? I think you have you have to set a transient one. You have to try to obtain a small courant number. You can control it modifying the timestep. Are you initializing the calculation? Let me know your initial setting Bye |
February 25, 2010, 07:06 |
#6 | |
Arvind
Rep Power: 17 |
@ Mach000
Yes u are right. I am getting a fatal overflow error. I am working with a steady state simulation only. Should i use transient type? The problem i am trying to solve deals with Hypersonic velocities so my initial Mach is around 5.5 and i hav used supersonic condition at inlet giving cartesian velocity and pressure. The various B.Cs are as follows INLET1: Supersonic with Cartesian velocity and Pressure INLET2 : Subsonic with Normal velocity component(as suggested by u and Timon) OUTLET: Supersonic OPENING: subsonic with static pressure(Entrain). Quote:
Any help in this regard would be very much appreciated. Thnx in advance!!!! |
February 25, 2010, 07:34 |
SanS
Rep Power: 17 |
Hi, whats the timestep your using? try a small timestep in the initial stages and then ramp it up. These issues are discussed in the help files.
Ciro Cannavacciuolo
Rep Power: 17 |
Supersonic?
I've not experience in this kind of simulation. Could you explain me where are the BC "opening" and "outlet"? From your doc I don't see those BC. Initializing is a step in which you set the initial fluid dynamics features of the flow. Most of cases, the overflow is due to bad initial conditions. In CFX try to find the icon with "t=0" as symbol. Let me know |
February 25, 2010, 08:01 |
#9 |
Arvind
Rep Power: 17 |
@ sans
The time step i am using is 0.1 sec @mach000 I am working in aerospace domain The model which i have shown is actually a simplified model of a space shuttle .I think now u will be clear why am using Hypersonic velocities. As u said i have checked the initial conditions ( from that t=o icon) .In that everything is set to automatic with velocity type as cartesian. Should I change that setting from "Automatic" to "Automatic with value" and give ma conditions in der.? The modified domain showing opening and outlet is attached. Please check it and let me know. |
February 25, 2010, 08:08 |
#10 |
Ciro Cannavacciuolo
Rep Power: 17 |
ok,
know it seems clearer. AS first step i should define symmetry conditions instead of your opening (top and down). Then, I should change your outlet with opening, but you can try with outlet, too. About timestep: In my opinion it is too high. If you want you can send me your pre file (I've cfx v11). I can check it better |
February 25, 2010, 08:13 |
#11 | |
Arvind
Rep Power: 17 |
@ mach000
Thnx for ur prompt replies. Actually i have defined the front and back surfaces as the symmetry . If I change ma opening to symmetry( as suggested by you) then what shud i assign for the front and back surface? Wat difference will it make if i change the opening to symmetry and outlet to opening????? Hope I am not loading u with questions About timestep: I wil try reducing it. Quote:
Give me ur mail ID so that i can send my pre file. and one more thing.....Is my simulation a transient one?????? |
February 25, 2010, 09:35 |
#12 |
Ciro Cannavacciuolo
Rep Power: 17 |
my mail is cannavacciuolociro@gmail.com
in front and back is correct to assign simmetry boundary condition. If top and down BC are quite far from the object, they are in a not disturbed zone, where the flux is very regular. So, you don't need to simulate something that enter or go out from your domain. There is another kind of solution that yuo can consider but for now i think we can try with the one i've just try to explain to you. About the opening condition instead of the opening: when you set outlet, cfx will think that from that boundary the flux can only goes out. If there is something different (for exemple a vortex) some flow will "enter" into the domain from that boundary. This could be a problem for the solver. If you set opening, instead, cfx "knows" that from that boundary the flow could enter or go out. Sorry for my english, i hope you undestand me. |
February 25, 2010, 09:43 |
#13 |
Arvind
Rep Power: 17 |
Thnx a ton!!!!
I wil change my outlet to opening and my opening to symmetry as u suggest and try solving my problem. Moreover I wil mail the CFX-PRE file to ur mail. Pls have a look at it and let me know. |
February 25, 2010, 09:51 |
#14 |
Ciro Cannavacciuolo
Rep Power: 17 |
ok!
I'm waiting for your file |
February 25, 2010, 09:59 |
#15 |
Arvind
Rep Power: 17 |
I have sent the file to ur mail......Pls check ur inbox and let me knw whether u r able to access it....Thnx
February 25, 2010, 10:05 |
#16 |
Ciro Cannavacciuolo
Rep Power: 17 |
i'm checking your files.
I'll answer you from my private address to your. |
February 25, 2010, 10:26 |
#17 |
Ciro Cannavacciuolo
Rep Power: 17 |
i sent you a mail to your private address.
February 10, 2017, 05:54 |
3 different inlets,3 diff fluid
#18 |
karthikeyan subramaniam
Rep Power: 9 |
good morning
my domain consist of 3 different inlets,. at 1st inlet water 2nd milk 3rd which is open to atomspere my doubt is how to set this boundry condition in fluent?? wat is the name of milk in fluent material property?? thank you |
February 10, 2017, 17:11 |
#19 |
Rep Power: 143 |
Try the fluent forum.
Multiple Solid Domains - Interfaces | Scott | CFX | 8 | July 31, 2008 15:20 |
buoyancy in two separate domains | DenizeN | FLUENT | 0 | January 16, 2008 15:33 |
Differents fluids separated by wall | phil | FLUENT | 0 | January 18, 2007 02:43 |
can i put 2 different fluids into to 2 domains? | prayskyer | CFX | 1 | May 18, 2006 08:47 |
Multiple domains - buoy. ref. temp. setting | Forrest | CFX | 8 | February 22, 2006 13:43 |
