July 17, 2015, 06:38 |
Uncommon stirrer case simulation setup
Józef
I would like to ask you about the simulation strategy for a case I do. I have a cylindrical tank in which there is a kind of rotating stirrer which is elliptical. There are two problems with this case: -Ellipse major axis length is close to the tanks diameter. -The fluid region is all around the ellipse. I don't want to use the immersed solid since I need temperature distribution in the ellipse. I am afraid that the mixing vessel case is not necessarily feasible in my simulation. Thank you and regards |
July 17, 2015, 08:19 |
Rep Power: 143 |
It would be pretty unusual to do a rotating machinery simulation with anything other than rotating frames of reference.
Your mesh appears to have very big jumps in element edge length. This may cause convergence problems. |
July 19, 2015, 06:46 |
Józef
Thanks. I thought there may be other approaches, it would be interesting to compare different solutions.
Yes this mesh is a first draft, just to make sure the geometry and bc are correct. |
OpenFOAM Case Setup Needed | mpl | CFD Freelancers | 4 | October 10, 2013 16:14 |
How to read or write case by commands during simulation with Fluent | lzgwhy | FLUENT | 4 | April 20, 2011 22:02 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
Drying simulation setup | H | CFX | 0 | May 12, 2006 14:27 |
Unsteady state case setup | Christian | FLUENT | 2 | February 16, 2003 17:11 |
