June 9, 2015, 12:42 |
FSI problem
Amir Foad Farshchi
Rep Power: 11 |
Hi guys,
I am working on a micro pump by coupling structure and CFX. I want to do transient CFD analysis, but after structural time step finishes, ANSYS says an error: fatal error, can not read mesh deformation data from interface. This happens when the membrane goes up in diaphragm. I have not this problem in steady-state analysis. I would appreciate if you help me. Thanks in advance |
June 12, 2015, 10:43 |
Matthias Voß
Rep Power: 20 |
Check the FEM results.... the solver is telling you " i cannot get the displacement..." because ANSYS crashed in the very last timestep. Often you can check the ANSYS.rst for what has happend in the "crashed, unconverged" last load step to get an idea what probably caused the problem.
June 15, 2015, 13:33 |
Amir Foad Farshchi
Rep Power: 11 |
Dear Mathias,
I checked the .rst file, but still don't understand where the error comes from |
June 15, 2015, 15:09 |
FSI problem
Matthias Voß
Rep Power: 20 |
Did the last ansys loop reach convergence?
June 16, 2015, 07:11 |
Amir Foad Farshchi
Rep Power: 11 |
No it doesn't converge at the last step
June 16, 2015, 07:40 |
Matthias Voß
Rep Power: 20 |
Did you check where the residual is bad? Activate the NewtonRaphson-option in the Ansys results and re-run the case.
How big was the displacement for this last time step? Did the cfx solver reach converge? At which point in the simulation did the error occur? How was the interface convergence? How did you set the relaxation of the transferred variables? There are many reasons for the coupling to go wrong. |
June 16, 2015, 11:09 |
Amir Foad Farshchi
Rep Power: 11 |
I set Raphson-Newton to Full.
at the last step the deformation is 9 microns (the geometry is the circular shell with 750 microns radius. after 5 Iteration in interface, the simulation stops. CFX solver didn't even start. Interface residual is almost constant after 3rd iteration. I set the convergence to 1E-4 RMS for mesh displacement and 1E-2 for interface variables. The Initial condition is set to zero for all velocities and relative pressure. And eventually I got this error in structural : Element 1 has excessive thickness change By the way, thank you for your help man. |
June 16, 2015, 11:56 |
Amir Foad Farshchi
Rep Power: 11 |
I forgot, set under-relaxation to 0.75
Thanks Matthias |
June 16, 2015, 13:00 |
FSI problem
#9 |
Matthias Voß
Rep Power: 20 |
What do you mean by "constant after third iteration"? Did the error rise up in the First Time step? Sounds like the initial deformation/stress is to much. How do you change fluid conditions from initial to working conditions? Can you Post a pic of both CFD And FEM Part?
June 16, 2015, 13:01 |
#10 |
Amir Foad Farshchi
Rep Power: 11 |
residual values neither do go up nor down
actually I reduced the number of steps and the error removed but I got negative volume element instead |
June 16, 2015, 13:02 |
#11 |
Amir Foad Farshchi
Rep Power: 11 |
actually I reduced the steps and the error removed but I got negative volume element instead
June 16, 2015, 19:13 |
#12 |
Rep Power: 143 |
August 9, 2015, 22:27 |
#13 |
hallow rocks
Rep Power: 12 |
I am trying to do FSI simulation of sinusoidal flow in elastic tube. Even i am having same error (excessive change of thickness in element). Did you resolve it? |
August 10, 2015, 05:47 |
#14 |
Amir Foad Farshchi
Rep Power: 11 |
you should find an optimum element size to avoid negative volume. This link may help you: http://www.cfd-online.com/Wiki/Ansys..._went_wrong.3F |
August 10, 2015, 07:34 |
#15 |
hallow rocks
Rep Power: 12 |
ok thanks for the info
Simple FSI (fluid structure interaction) Problem | kilroy | Main CFD Forum | 0 | January 7, 2015 14:42 |
Defining contact regions in FSI problem.!!! | sreemvlk | ANSYS | 0 | June 12, 2014 00:33 |
prestrain in FSI problem | mina.m | STAR-CCM+ | 0 | October 31, 2013 11:39 |
divergent of a FSI problem | edooo0 | FLUENT | 0 | August 5, 2013 17:54 |
FSI MODELING PROBLEM (pinball)!!! | smn | CFX | 1 | September 16, 2009 00:33 |
