Material properties problem in two different domains |
October 8, 2015, 08:30 |
Rep Power: 16 |
Hello I have a problem yet discover it recently in CFX-Pre. I have two domains for two different fluids : water which flows at the upper part of the channel (see pictures) and oil flowing at the lower part of the channel . Now when i define fluid and particles definition for domain water and select material as water i see this material found in oil domain too and when i tried change oil domain material to oil water domain will change to oil too what the problem ?
mariam |
October 8, 2015, 09:44 |
Rep Power: 32 |
This type of simulation falls in the "advanced category", and you should be careful.
Go to Edit/Options, Enable Beta Features, and Disable Constant Domain Physics. Once you disable the "safety checks", you must carefully verify every boundary condition, model details, and consistency since the software will not do all of them for you.. It has been done, but it may take a few tries.. |
October 8, 2015, 10:09 |
#3 | |
Rep Power: 16 |
I cannot find safety checks? did you mean Automatic physics update?
October 8, 2015, 10:45 |
Rep Power: 32 |
Constant Domain Physics are the "safety checks".
October 8, 2015, 10:56 |
Rep Power: 16 |
Ohh I disabled both of constant domain physics and automatic physics update? is it effect the results if they both disabled because my run in progress now and do not hope to stop it?
simulation with ideal gas material properties | Ana | FLUENT | 5 | July 7, 2019 00:36 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
Vaiable Material properties | Pialisen | FLUENT | 2 | November 29, 2006 13:12 |
material properties | new-user | Siemens | 0 | October 21, 2004 10:15 |
