Error while running cfx in parallel configuration
Like Tree3Likes
  • 2 Post By Lance
  • 1 Post By Светлана
Old   October 17, 2015, 12:45
Default Error while running cfx in parallel configuration
stater's Avatar
H. Omar
stater is on a distinguished road
Hi everyone,
I am currently trying to run CFX (v16) in parallel configuration using the slurm manager. I used runCFX.sh script which is as follows:
!/bin/bash
srun hostname -s > /tmp//hosts.$SLURM_JOB_ID
if [ "x$SLURM_NPROCS" = "x" ]; then
if [ "x$SLURM_NTASKS_PER_NODE" = "x" ];then
SLURM_NTASKS_PER_NODE=1
fi
SLURM_NPROCS=`expr $SLURM_JOB_NUM_NODES \* $SLURM_NTASKS_PER_NODE`
fi
# use ssh instead of rsh
export CFX5RSH=ssh
# format the host list for cfx
cfxHosts=`tr '\n' ',' < /tmp//hosts.$SLURM_JOB_ID`
# run the partitioner and solver
/usr/ansys_inc/v160/CFX/bin/cfx5solve -par -par-dist "$cfxHosts" -def ./AADL2.def -part $SLURM_NPROCS -start-method "Platform MPI Distributed Parallel"
# cleanup
rm /tmp/hosts.$SLURM_JOB_ID
I submitted the job with the following command line
sbatch -n 10 -N 2 -p mypartition -t 10 ./runCFX.sh
i obtained the following error in the slurm output file:
<IBM Platform MPI>: : warning, dlopen of libhwloc.so failed (null)/lib/linux_amd64/libhwloc.so: cannot open shared object file: No such file or directory
An error has occurred in cfx5solve:
The ANSYS CFX partitioner was interrupted by signal SEGV (11)
Can anyone help me to solve this issue? Thank you
stater is offline   Reply With Quote
Old   October 19, 2015, 01:59
Lance
Lance is on a distinguished road
We have had problems getting Platform MPI Distributed Parallel to run with SLURM, and got exactly the same error as you. Ansys support wont help since they dont support it...
If I remember correctly it was solved by either using Intel MPI Distributed Parallel and/or unsetting the SLURM_GTIDS environment variable.
stater and Светлана like this.
Lance is offline   Reply With Quote
Old   October 19, 2015, 12:59
stater's Avatar
H. Omar
Hello sir,
I confirm, the unsettling of the variable SLURM_GTIDS has allowed to solve the problem
Thank you a lot
Old   March 18, 2016, 00:02
Svetlana Tkachenko
Светлана is on a distinguished road
Thank you, Lance,
We added 'unset SLURM_GTIDS' to the job script and the job runs now,
Now instead of 2 we have 5 people on the planet who know of this workaround.
Светлана is offline   Reply With Quote
Old   March 30, 2016, 22:17
EvanOscarSmith's Avatar
Evan Oscar Smith
EvanOscarSmith is on a distinguished road
Thanks so much!
I was having this same issue with CFX 17.0 and the unset SLURM_GTIDS command has fixed it.
EvanOscarSmith is offline   Reply With Quote
Old   May 3, 2016, 18:51
hmp
hmp is on a distinguished road
Thank you for this info.
In case someone is trying to run Abaqus in parallel on one of XSEDE resources (e.g. SDSC Comet) then adding 'unset SLURM_GTIDS' before the ABQ command will get rid of errors about MPI.
Make sure you have parallel_mode=MPI in the ABQ command.
Best,
hmp is offline   Reply With Quote
Old   June 20, 2016, 11:53
Kyriakos Vafiadis
k.vafiadis is on a distinguished road
Send a message via Skype™ to k.vafiadis
unset SLURM_GTIDS worked for me too
Originally Posted by Светлана View Post
Thank you, Lance,
Kyriakos Vafiadis
Mechanical Engineer, PhD candidate
k.vafiadis is offline   Reply With Quote
Old   February 27, 2017, 07:08
Neys Schreiner
Neys Schreiner is on a distinguished road
Also worked here, added:
unset SLURM_GTIDS
to my job script below the usual module load commands and voila.
Thanks!
Neys Schreiner is offline   Reply With Quote
Old   May 11, 2017, 19:01
Alex
alaspina is on a distinguished road
Anyone know how to do this for an interactive session?
alaspina is offline   Reply With Quote
Old   May 11, 2017, 23:56
Svetlana Tkachenko
Alex, do you mean a CFX session on a GNU/Linux computer? Add the "unset SLURM_GTIDS" line to your bashrc or bash profile.
alaspina likes this.
cfx, parallel, slurm
OF 2.0.1 parallel running problems moser_r OpenFOAM Running, Solving & CFD 9 July 27, 2022 03:15
Problem running cfx on hpc beyonder1 CFX 4 September 14, 2015 02:35
RSH problem for parallel running in CFX Nicola CFX 5 June 18, 2012 18:31
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 09:38
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
