Trade off between Y+ and Solution convergence(CFX+WorkBenchMesh) |
November 7, 2015, 00:29 |
AJ
Rep Power: 12 |
I am working with CFX 16.1 in combination with Ansys workbench mesh.And i use SST for most of my simulations. For convergence I mostly look for Residual Max value(velocity, Pressure and energy). I am getting into following combinations, Bad Mesh quality(1E-04) and more skewed elements + Skewed first layer prism(I use smooth transition for inflation) = good y +(y+<7) + bad convergence (pressure and velocity max residual above 1E-02) comparatively Good mesh quality(1E-02) and minimum skewed cells + controlled first layer height of prism, which is also the main culprit for reducing mesh quality = Bad Y+(Y+>11) + good convergence(pressure and velocity max residual below 1E-03) I am aware that first layer is an important factor, but how can the first layer be improved without affecting the mesh quality and its skewness using workbench mesh. so that both Y+ and convergence can be satisfied. And in bad convergence Runs(decided by means of max residual), when i look into the RMS Residual values of pressure and velocity i see its below 1E-03. Is that means there are only few places with is running into bad convergence ?? These are my observations. And sorry i may not have results or plots with me. |
November 13, 2015, 10:06 |
Rep Power: 10 |
There's an option in CFX-Pre under Output Control->Results->Output Equation Residuals which allows you to plot your residuals in CFX-post like any other variable. This can be quite useful when troubleshooting bad mesh elements that are causing poor convergence.
grid dependancy | gueynard a. | Main CFD Forum | 19 | June 27, 2014 21:22 |
Why 3D solid-pore geometry showing diverged solution? | Sargam05 | OpenFOAM | 0 | December 3, 2012 15:45 |
Analytic solution for 2D steady Euler equations | jojo81 | Main CFD Forum | 0 | October 15, 2012 12:05 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
