Expression: Should dimensions be included? And should spaces be used?
Old   November 10, 2015, 15:17
Default Expression: Should dimensions be included? And should spaces be used?
sadjad
sadjad is on a distinguished road
Hi
In CFX , when we write an expression, do need dimension is written?
for example : Den*g*(0.5[m] -y) or 1000 [kg m^-3]
And need locate or put SPACE between values and dimension or not?
what mines [.....]
How write an expression?
sadjad is offline   Reply With Quote
Old   November 10, 2015, 16:48
Opaque will become famous soon enough
Let us say this is your expression set
LIBRARY:
  CEL:
     EXPRESSIONS:
        MyDen = 1000 [kg m^-3]
        MyBuoyForce = MyDen * ( 0.5 [m] - y ) * g
     END
   END
END
I always space my [ .. ] by one space from the preceding value, as well as between items in the expressions. Never failed me.
Keep in mind that a given expression, such as MyDen, it is not only the value but its dimension as well; therefore, when you reference it somewhere else you only refer the variable name and not its components (value or dimensions)
Opaque is offline   Reply With Quote
Old   November 10, 2015, 22:08
sadjad
Thanks Opaque.
My expression is according below but it dosnt answer me :
What is my error?
Den : 1000 [kg m^-3]
InPress : Den*g*(0.5[m] -y)
WaterX : 1 [m]
AirVF : Step((x-WaterX)/1[m])
WaterVF : 1-AirVF
and , in Global Initialization > Fluid Settings , when type "WaterVF" or "AirVF" ,cfx give me error and wants numerical value and dosnt accept "WaterVF" or "AirVF"
Old   November 12, 2015, 14:13
Antanas is on a distinguished road
Originally Posted by sadjad View Post
Thanks Opaque.
What is my error?
WaterX : 1 [m]
WaterVF : 1-AirVF
What kind of error? What is range for x?
Antanas is offline   Reply With Quote
Old   November 16, 2015, 02:42
sadjad
my range of x=1 m
Old   November 16, 2015, 08:57
Your example uses : instead of =. Is that correct ?
Old   November 16, 2015, 15:53
sadjad
my x value is 1
ok ?
Old   November 17, 2015, 07:45
my x value is 1
ok ?
And the error is.... ?
