Coupling a fortran file with CFX
Like Tree1Likes
  • 1 Post By ghorrocks
Old   October 24, 2015, 03:18
Default Coupling a fortran file with CFX
M. A. Moghanloo
mahdiaghaie2003@gmail.com is on a distinguished road
Dear friends
I have time dependent first order differntial equation, solved by runge kutta method in a fortran file. The out put of the calculation is power for a heated pipe. Now how i can compile or execute the fortran file with the simulated pipe in cfx for a transient case? I do not have any experience for this type of coupling.
Thanks
mahdiaghaie2003@gmail.com is offline   Reply With Quote
Old   October 24, 2015, 05:22
If the fortran calculation is not coupled to the CFD it is very easy - just put the output into a 1D interpolation function.
If the fortran is coupled to the CFD you will need to put the fortran (or a link to it) in a user fortran routine.
Old   October 24, 2015, 05:52
M. A. Moghanloo
Regarding to problem physics, it is impossible to run fortran and cfx in decoupled format (the fortran file needs some parameters of fluid domain like density and velicity during run. The code gives feedbacks from fluid domain and then calculates power for cfx). Now how i can couple my code with cfx. Please explain the procedure step by step.
Old   October 24, 2015, 05:56
My last post described what is required for a coupled fortran routine. There are some examples of how to do this in the CFX documentation. I do not have time to write a step by step guide, especially as one already exists.
highorder_cfd likes this.
Old   October 24, 2015, 06:29
M. A. Moghanloo
Thanks a lot for answer. How i can have this document ?Please if possible send it for me.
Old   October 24, 2015, 08:31
Antanas is on a distinguished road
If you have CFX, then you have help files.
Antanas is offline   Reply With Quote
Old   November 17, 2015, 20:00
Nguyen Duc Thuyen
tandem is on a distinguished road
1. You read carefully the part 18.2.1 in CFX of Help CFX. You will know the location to get your Junction Box Routine or User Function.
2. Write Junction Box Routine or User Function to caculate coupling
3. Note that, you have to compile your Junction Box Routine or User Function by "cfx5mkext -64bit name's Junction Box Routine or User Function"
4. Read examples of part 18.8 in CFX of Help CFX
tandem is offline   Reply With Quote
Old   November 26, 2015, 07:28
Question
Emil Günther
CFXNewbie is on a distinguished road
Thank you for your answers so far!
I have a very similar problem. I have read chapter 18: User Fortran, but I still have no idea how to compile the code. Do I need just a standard Fortran 77 compiler here? As a simple example, I wanted to test this user routine:
#include "cfx5ext.h"
dllexport(test)
SUBROUTINE TEST (NLOC,NRET,NARG,RET,ARGS,CRESLT,CZ,DZ,IZ,LZ,RZ)
C
INTEGER NLOC,NARG,NRET
CHARACTER CRESLT*(*)
REAL ARGS(NLOC,NARG), RET(NLOC,NRET)
C
INTEGER IZ(*)
CHARACTER CZ(*)*(1)
DOUBLE PRECISION DZ(*)
LOGICAL LZ(*)
REAL RZ(*)
C
RET = 2000*ARGS(1,1)
END
Using a Fortran 77 or Fortran 90 compiler produces errors. What do I have to do?
Thanks a lot!
CFXNewbie is offline   Reply With Quote
Old   November 26, 2015, 11:24
Opaque will become famous soon enough
RET is an array of size NLOC x NRET; therefore, should you not fill in NLOC x NRET entries instead of
RET = 2000 * ARGS(1,1)
For example,
DO IRET = 1,NRET
DO ILOC = 1, NLOC
RET(ILOC,IRET) = 2000 * ARGS(1,1)
ENDDO
ENDDO
Also, you did not say what error has been detected by the compiler..
Opaque is offline   Reply With Quote
Old   November 30, 2015, 12:34
Emil Günther
Thank you for your help!
I've tried
dllexport(reibmodell)
SUBROUTINE REIBMODELL (NLOC,NRET,NARG,RET,ARGS,CRESLT,CZ,DZ,IZ,LZ,RZ)
C
C
INTEGER IZ(*)
CHARACTER CZ(*)*(1)
LOGICAL LZ(*)
REAL RZ(*)
C
DO IRET = 1,NRET
DO ILOC = 1, NLOC
ENDDO
ENDDO
END
Thanks a lot!
Old   November 30, 2015, 14:23
It would be good to see your compilation line.
It seems the preprocessing directive # are not being used, that is the compile line did not include cpp, or fpp support.
Old   December 1, 2015, 04:39
Emil Günther
I think so, too.
Does #include "cfx5ext.h" only work, when Ansys CFX is installed on the system? Because on this machine I don't have Ansys. On the computer, on which I can use Ansys I can compile only Fortran 90 code.
On the attached image you can see the complete Force 3.0 screen with source code, errors....
Thank you!!
Old   December 13, 2015, 07:39
Emil Günther
Think I finally got it, thanks!
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
