Willian Andrećo
Rep Power: 10 ![]() |
I'm using CFX 14.5 to simulate flow inside a chamber. I need to use a small fan rotating. For this, first I created the chamber domain because is more complicated. Inside the chamber, I removed a volume of a cylinder and insert the impeller as a second domain. After, I drew the cylinder involving the impeller. Therefore, I have 3 domains: chamber, impeller and cylinder (See attached). On CFX-Pre I set the chamber domain as stationary with its boundary conditions and the impeller and cylinder in a second domain, rotating. How can I set the interfaces (cylinder and chamber) properly? Is there any mistake in the geometry as I drew? I didn't now how to draw the cylinder and the propeller in the same domain, because when I unfreeze the cylinder, the impeller disappear. Apologize for the English, Portuguese is my first language! |
Rep Power: 143 ![]() ![]() ![]() ![]() |
This is covered in the rotor/stator tutorials which come with CFX. Have a look at them in the documentation.
air mixing, cfx & air content, cfx 14.5, fan, impeller |
how to start for modelling n meshing a mixing tank with impeller | jeevan | ANSYS Meshing & Geometry | 9 | July 16, 2013 07:06 |
Different temperature to air and to solid , cfx, city modeling | kordou | CFX | 1 | January 19, 2011 19:20 |
Air & water mixing problem | praveenkumar | FLUENT | 0 | April 15, 2010 02:14 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
To determine mixing tank with anchor impeller | p prajapati | FLUENT | 1 | December 12, 2007 15:27 |
