January 15, 2016, 04:29 |
section discharge vs time
Sara
HI=)
I would like to plot the discharge of one fluid through a section vs time (i.e the hydrograph). But the problem is that transient graphs allow to plot variables vs time just in one point. I tried the following procedure but I don't think the result I get makes sense..Can you suggest me another strategy? This is what I did: in the post processing I defined an expression "discharge" which compute the discharge as the area integral of the fluid velocity in the section of interest: discharge=areaInt(fluid1.Velocity)@last section before the dam then I created a graph specifying: graph type: transient data source: the expression discharge x axe: the time variable at this point I suppose the programme will plot the discharge in function of time but actually I have to specify also the y axe variable. This make me think I am not on the right road.. Thanks a lot for your help! Sara |
January 15, 2016, 05:45 |
Rep Power: 143 |
If you don't like the way CFD-Post does charting then export the data and use a graphing package you are familiar with. Things like excel, matlab, tecplot, python, gnuplot and many others are much easier to use and have more features.
discharge vs time |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
[solidMechanics] solidMechanics gear contact in rotation | nlc | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 3 | January 11, 2015 06:41 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
