February 14, 2016, 07:13 |
data text for geometry
Rep Power: 11 |
hello every body,
i want to import data text file for geometry in cfx, any ideas? |
February 14, 2016, 16:41 |
Rep Power: 143 |
If you want to import geometry into a solid modelling package then try the user forum for your solid modelling package. If you are using DesignModeller try the ANSYS geometry and meshing forum.
If you want to import a mesh directly into CFX - this is not easy as CFX does not support simple meshing formats. But it does support a number of text based mesh format such as CFX4, fluent and some others. |
[General] Advice on post processing compressor blade data in paraview | Jack001 | ParaView | 0 | February 4, 2016 17:16 |
Fill in user grid text file with ANSYS Emag data? | AlexBbb | Electromagnetics | 0 | August 27, 2015 07:57 |
Exporting some results data at text file format | Asghari_M | OpenFOAM Programming & Development | 4 | May 6, 2015 16:46 |
How to setup a simple OpenFOAM cluster? | TommiPLaiho | OpenFOAM Installation | 3 | October 27, 2013 15:15 |
report data in text file | lucus | FLUENT | 3 | August 18, 2007 17:09 |
