March 3, 2016, 07:15 |
only automatic meshing works,
kasra
Rep Power: 10 |
hello
im trying to mesh an air to air heat exchanger using multizone meshing method but every time i get an error saying (with all the default values): Update failed for the Mesh component in Fluid Flow (CFX). Error updating cell Mesh in system Fluid Flow (CFX). View the messages in the Meshing editor for more details. and in the meshing editor it says: MultiZone blocking decomposition failed. If you right click on this message, you may be able to "Show problematic geometry" and try a different approach to meshing those bodies. and also other meshing methods dont work either except automatic one. i would appreciate any help. thanks in advance |
March 3, 2016, 08:01 |
kasra
Rep Power: 10 |
now im getting a new error saying:
The MultiZone meshing has completed, but no volume elements were created. This may be caused by unsupported circular sweeps. and: MultiZone meshing failed during meshing of blocks. Please verify the meshing parameters. |
March 3, 2016, 17:14 |
Rep Power: 143 |
Try the geometry and meshing forum.
[ANSYS Meshing] Meshing a wedge-wire screen: in 2D works fine, in 3D lasts for ages. | kubawlo | ANSYS Meshing & Geometry | 7 | April 25, 2022 22:38 |
Meshing Process | sidharth9426 | STAR-CCM+ | 4 | September 15, 2015 03:31 |
Running parallel case after parallel meshing with snappyHexMesh? | Adam Persson | OpenFOAM Running, Solving & CFD | 0 | August 31, 2015 22:04 |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 05:22 |
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! | lau06165 | ANSYS Meshing & Geometry | 1 | March 22, 2010 01:09 |
