April 19, 2016, 12:31 |
minimum surface angle
mao
Rep Power: 10 |
hey, i use mesh motion in cfx. and i wanna have a level to check mesh quality after simulation, as a consequence, i chose minimum surface angle as a level, but i am not sure what degree of this variable is ok for guide vanes?
thank you |
April 19, 2016, 18:39 |
Rep Power: 143 |
It is problem dependent so there is no universal answer. Single phase incompressible flows are tolerant of poor quality meshes, but free surface flows and flows with shock waves require very high quality meshes.
You have to determine what is acceptable in your case by a sensitivity analysis. |
mesh quality, minimum surface angle |
Remeshing and Minimum Orthogonality Angle | ashtonJ | CFX | 2 | May 7, 2015 19:11 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
contact angle of surface tension | boesendorfer | FLOW-3D | 0 | April 26, 2014 10:55 |
Comsol (4.3): convert parametric surface into block? | sgalaz | COMSOL | 0 | November 9, 2012 09:20 |
Calculating forces on a non-closed surface | ScottN | FLUENT | 0 | March 1, 2011 17:18 |
