November 23, 2019, 15:41 |
Flow through a moving diaphragm
Rep Power: 7 |
Hi everyone, I am going to use ANSYS-CFX and FSI-model a pulsating flow through a valve with a deformable diaphragm. In the initial step, the diaphragm is undeformed and prevent any flow through the valve (so there is no mesh after the diaphragm). However, when the inlet flow increases, the diaphragm is deformed and allows the flow to pass. For this situation, I need to have meshes after the diaphragm to model the flow through the valve. My question is how I should create the meshes for the whole domain of the problem?
November 24, 2019, 19:04 |
Rep Power: 143 |
If you want to model something which is closed and opens you have a few options, each with their own advantages and disadvantages:
* Use a GGI as that handles opening and closing easily. But you need to slide the surfaces over each other and any valves have flat faces which close so this is a simplification. * Start the simulation with the valve cracked open a tiny amount. Then the simulation just proceeds from there. This avoids the problem of the moment the valve cracks open but means you can't start from properly closed, and also mesh stretching in the valve seat can be an issue * Similar to the previous option, but use a momentum source term to stop the flow when you define the valve is shut. * The most accurate way of handling this is with dynamic remeshing, as then you can handle anything - as long as you can define the remesher to do it. This is a lot harder than the other approaches. Warning: I have no idea if dynamic remeshing works well with FSI. In general people seem to like the hardest possible approach, so if you want to do dynamic remeshing have a look on the ANSYS customer webpage for tutorials on it.
November 24, 2019, 19:20 |
#3 | |
Rep Power: 7 |
dynamic mesh, fsi, moving mesh |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Moving a Cylinder in cross flow after solving Dynamics equations of motion | maruthamuthu_venkatraman | OpenFOAM | 1 | November 19, 2009 13:55 |
Modeling flow over a moving object | psd | Main CFD Forum | 3 | October 21, 2009 07:46 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
