May 1, 2016, 09:11 |
pressure drope does not work!
Taron
Rep Power: 10 |
Hi to all, I am doing a steamflow simulation in vertical steel tube with diametre 12mm,,,,, reference pressure 60 bar,,,,, buoyancy ref density 33 kg/m^3, as with this pressure saturated steam density equal to it (as it is saturated flow, it is somekind of twophase flow, gas with water droplets),,,,, inlet 1m/s,,,, outlet static pressure 0bar,,,,,, So the results must show pressure drop with the length of tube, but it doesn't, even it shows excess,, in contrast, with waterflow in same conditions I get the pressure drop! Why there is no pressure drope, maybe with steam it should be like that, if yes please explane why, thank you.
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 12:23 |
CFX Solver stopped with error when requested for backup during solver running | Mfaizan | CFX | 40 | May 13, 2016 06:50 |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 13:45 |
UDF to define or adjust pressure??? | engahmed | FLUENT | 0 | July 6, 2010 17:19 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
