June 18, 2016, 17:12 |
Penetratig Mesh
Ferruccio Rossi
Rep Power: 9 |
I am running a two ways FSI of a wing with CFX. In transient structural, I assigned the edge contacts (first picture) but I get a penetrating mesh (second picture). When I check the final results, I get an equivalent stress of 37 MPa about the wing root. To verify the results, I run another simulation, but this time I use one single surface for the wing support and the wing skin (third picture). The result I get is only 20 MPa!! Why? 1. Is mesh penetration bad? 2. When I use the single surface to avoid penetration, it looks like the equivalent stress (fourth picture) is not at the wing root (where it should be). Why? Thank you |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
