June 19, 2016, 05:26 |
overflow error
farzad
Rep Power: 9 |
Hello everybody.
I'm running a simulation about Temperature distribution on surface in steady state condition and i want to solve my case in steady state condition . On CFX - Solver I got this error: ERROR #001100279 has occurred in subroutine ErrAction. Floating point exception: Overflow Do you know which could be my mistake? Thank you |
June 19, 2016, 06:19 |
Rep Power: 143 |
June 20, 2016, 12:26 |
#3 | |
Aja
Rep Power: 14 |
Usually this problem is related to mesh quality. check skewness and aspect ratio in your mesh. |
June 20, 2016, 20:37 |
Rep Power: 143 |
Checking the simulation is correctly set up and using the right physics is the first thing to check. Mesh quality is number two. This is all described in the FAQ.
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 06:35 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
