Expression for reading velocity and torque on a rotating disk - errors received. |
June 20, 2016, 16:21 |
AH
Rep Power: 13 |
Used this expression to read velocity on a rotating disk about z axis.
probe(Velocity u )@point where point is a source point on the disk edge. Got this error message when run"illegal argument for callback function probe (Velocity i-n Stn Frame u)@SP1. ALSO wrote an expression to read torque on the same disk using this expression. torque_z ()@disk face and got this error message at the set up stage. Although it is valid to create an expression that uses such a function, the processor does not support its evaluation. Hope someone can help out. Thanks in advance. |
June 20, 2016, 16:38 |
Rep Power: 32 |
What release version of ANSYS CFX are you using ?
The error for the torque_z()@SP1 expression is correct since the pre-processor cannot evaluated a quantity that depends on the solution. The ANSYS CFX Solver, and the post-processor should be able to do so once the solution has been computed. I cannot reproduce the first error, but it seems like a typo in the expression. |
June 21, 2016, 02:11 |
Maxim
Rep Power: 12 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
Relationship between rotational velocity and torque question. | pa-dundas | FLUENT | 0 | September 3, 2011 10:04 |
