June 22, 2016, 03:16 |
Transition SST model error
JeongJu
Hello Everyone.
I got a problem which is transitional turbulence SST model error Parallel run: Received message from slave ----------------------------------------- Slave partition : 16 Slave routine : ErrAction Master location : RCVBUF,MSGTAG=1012 Message label : 001100279 Message follows below - : +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Floating point exception: Overflow | | | | | | | | | | | +--------------------------------------------------------------------+ Parallel run: Received message from slave ----------------------------------------- Slave partition : 16 Slave routine : ErrAction Master location : RCVBUF,MSGTAG=1012 Message label : 001100279 Message follows below - : +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine FPX: C_FPX_HANDLER | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ The error is shown by this. I don't know how to solve this problem. Also, if i do not use transition SST model, it is working. Best Regards JeongJu |
June 22, 2016, 06:23 |
Rep Power: 143 |
FAQ: http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F
So you clearly have a problem with the transitional turbulence model. That should give you some clue for where to look. |
July 5, 2016, 04:02 |
JeongJu
Thank you ghorrocks!
[OpenFOAM] an error in Calculator's equation | immortality | ParaView | 12 | June 29, 2021 00:10 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
