June 22, 2016, 04:19 |
simple 2D rotating disk-with rigid body
dyson ilia
Rep Power: 10 |
hello
i want to rotate a simple 2D rotating disk with rigid body(only rigid body). (attached pic) fixed rpm about disk center at all time - move in straight line-transient. plz help if possible |
June 22, 2016, 06:20 |
Rep Power: 143 |
Does the disc just follow a known path, or is it deflected by the forces acting on it? Are you interested in start up transients or just steady state?
It appears you can model this using an inlet velocity which includes both the ambient fluid speed and the ring motion. This means the ring is stationary, and the rotation can be modelled by tangential wall velocity. This is MUCH easier than what you propose. |
June 25, 2016, 02:53 |
re
dyson ilia
Rep Power: 10 |
hello
-transient from start -external force applied to disk - rigid body motion only thanks |
CEL code for simulating the equation of motion of a vibrating rigid body | mohamadaliv | CFX | 11 | October 19, 2011 04:30 |
Turbulent solver rigid body mechanics | philippose | OpenFOAM Running, Solving & CFD | 53 | July 16, 2011 13:35 |
vof rotating disk 2d | bene | FLUENT | 1 | October 24, 2010 13:18 |
Rotating Disk | MohsenZendehbad | FLUENT | 2 | July 13, 2008 13:43 |
simple rigid body motion UDF | Dan | FLUENT | 0 | January 11, 2006 05:48 |
