gtmDSDBReader.exe error
Old   June 30, 2016, 01:48
Default gtmDSDBReader.exe error
Alex
Red Ember is on a distinguished road
Good day to all
I'm trying to deal with flow over turbine blade with inner cooling in workbench. I chop body in few parts using NX and exported it to parasolid. Then created mesh cells for each body and tried to drag the first part into separate cfx module (links to setup cell). It required mesh cell updating. Then I launched setup cell and faced following error:
windows message about gtmDSDBReader.exe closing
ansys message:
System.ApplicationException: Application Error in CFX-Pre: ERROR
It was not possible to extract any mesh from the file:
D:\......\test geom_files\dp0\SYS\MECH\SYS.cmdb.
So, there was no domain in launched CFX module. Anyway, the second part was imported to cfx successfully.
How can I deal with it? Why gtmDSDBReader.exe works selectively?
Here was almost the same problem:
http://www.cfd-online.com/Forums/cfx...ting-mesh.html
How can I update gtmDSDBReader.exe? Should I reinstall ansys?
Thanks in advance
Red Ember is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
