July 1, 2016, 12:26 |
CFX SOLVER parallel error
Rep Power: 9 |
Hi all... this is my firts post when i find any solution.
My problem is cfx solver... When start mi .def file in solver, i select intel mpi distributes parallel; Select and add host from list, and play run. In cmd windows appaire : Abort: unable to connect to host 1 The ANSYS CFX solver has terminated without writing a results file. Command on host calcoloth04 exited with return code 0 I can not understand the problem.. i hope you can help me... TNX |
July 2, 2016, 06:52 |
Rep Power: 143 |
Does the simulation run when you do it serial? Does the tutorial examples run? Can you run a tutorial example in distributed parallel mode?
July 2, 2016, 07:15 |
#3 | |
Rep Power: 9 |
In serial and intel MPI local parallel mode no error. But i selected Intel MPI distributed parallel , error remote host not found. Show me error "command to host exited return with error 0" |
July 2, 2016, 08:06 |
Rep Power: 143 |
Have you followed the instructions to set up distributed parallel? It is not setup in the default installation, you need to do extra things to get it working. |
July 2, 2016, 09:24 |
Rep Power: 9 |
i followed the instruction for distrubuted parallel... but when i add new host and start run... return error code 0
July 3, 2016, 06:03 |
Rep Power: 143 |
Do you get this for all simulations when you run distributed parallel?
If so you have a problem in your setup (obviously). The parallel setup instructions are accurate and detailed so make sure you are following them. You might need to re-do the parallel setup to fix up the thing you missed. |
July 4, 2016, 13:38 |
Rep Power: 9 |
ok...
in sequence i installed: ansys 15.0 platform MPI. (Ibm and Intel) open 8636 on windows firewall and add Exception following the instructions. When i started the simulation, i select Intel Mpi distributed parallel. insert host and start run. But th problem persist. |
July 4, 2016, 19:36 |
Rep Power: 143 |
Does it work with platform MPI?
July 5, 2016, 02:53 |
#9 |
Rep Power: 9 |
July 5, 2016, 09:45 |
#10 |
Rep Power: 9 |
i resolve in part...
I have 5 host. host 1, host 2, host 3, host 4 and host 5 When i try to cfx5parallel -register-impi-user and add host2, all ok... running start without error. if try to add host3 with same command ( cfx5parallel -register-impi-user) The simulation show me error:" Unable to connect host 2" My question is: Cf5parallel can add only one host? If i have more host to add? what can i do? tnx |
July 5, 2016, 11:43 |
#11 |
Rep Power: 9 |
Updating....
I reinstall Ibm MPI & Intel MPI. reset caching password... Now INTEL MPI DISTRIBUTED RUN OK! My configuration: Windows server 2012 r2 with 4 Workstation xeon in lan. the problem now is that I do not know what I did to make it work |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 04:53 |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 09:40 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
