what are the boundary conditions for the propeller ? |
July 13, 2016, 01:39 |
Mostafa
Rep Power: 9 |
Hello!
I am trying to put a small propeller behind airfoil (2D case), the model of the propeller will follow the actuatior disk theory. there is no propeller design yet, just a discontinuity to increase the flow momentum to produce thrust. the picture is attached to be more clear. it will be modelled as a square with air inlet and exit. the mass of air entered the propeller will gain pressure and go out to the domain again. my question is: what boundary conditions i shall set in the propeller enternce and exit?? how i can control the thrust required? thanks in advance |
July 14, 2016, 06:11 |
Rep Power: 143 |
The rear boundary should probably be an outlet with either defined static pressure or average pressure.
You control the thrust by varying the strength of the momentum source. |
July 14, 2016, 12:39 |
#3 | |
Mostafa
Rep Power: 9 |
U mean that the face near the trailing edge is pressure outlet? |
July 14, 2016, 19:03 |
Rep Power: 143 |
The boundary face on the right side, labelled opening should probably be an outlet as I mentioned. An opening should work too if you want to go that way.
boundary conditions, propeller |
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
A problem about setting boundary conditions | lyang | Main CFD Forum | 0 | September 19, 1999 18:29 |
