Huge difference in Hybrid vs Conservative values in BC |
September 6, 2016, 10:08 |
Vitor Braga
Rep Power: 9 |
Hello, I'm getting a huge difference between the values of pressure in my Boundary Condition calculated by the Hybrid and Conservative methods. I know the difference between them, however I would expect both methods to provide values within certain range. Instead of that I'm getting 0.629 bar in the outlet for the Hybrid method (which is my actual BC), and rouhly 2 bar for the conservative method. Is this a sign that my mesh is not refined enough? I know for a fact that there's a significant pressure gradient at the outlet of my domain.
Best regards. |
September 6, 2016, 15:49 |
Rep Power: 16 |
If there is a significant pressure gradient at your outlet BC, and if the solution is well converged, I'd go with the conservative value because it is a part of solution while the hybrid is just your wish.
September 6, 2016, 19:16 |
Rep Power: 143 |
Hybrid and conservative values are only different in the volume adjacent to the wall. If you get such large differences between hybrid and conservative it suggests the volumes adjacent to the wall are a large proportion of the total boundary. This does not sound like a sufficiently fine mesh to me. But to be sure you should do a mesh sensitivity check.
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
max node values exceed max element values in contour plot | jason_t | FLUENT | 0 | August 19, 2009 11:32 |
huge difference in running time | Jimmy | Main CFD Forum | 5 | July 18, 2008 22:29 |
high difference between cell and nodal values | Trilok | FLUENT | 2 | November 13, 2003 03:38 |
Conservative finite difference scheme? | Linfeng BI | Main CFD Forum | 1 | October 10, 2002 12:17 |
