February 14, 2009, 06:19 |
Radiation with adiabatic wall
Hi experts!! I have a simple box with inlet, outlet and one windows,it's 2d, there is radiation, I have a radiation source and the the thermal radiation model is Monte Carlo. my domain is air. I would set adiabatic wall (the wall is only the line of the box, it hasn't thickness), but the problem is that if I set adiabatic wall, the temperature near the wall decreases also of 100 degree. the tutorial with radiation has only a fixed temperature wall, not adiabatic... (with a fixed temperature my model works, but it isn't as my physical case...). How could I resolve it? thanks
June 20, 2014, 12:43 |
HH
Rep Power: 12 |
I have the same problem. Can anyone guide me what to do with that? When I use adiabatic boundary condition (thermal energy) on the wall , I have non zero heat flux on the wall. What is the reason?
June 23, 2014, 09:47 |
#3 | |
Rep Power: 32 |
From the documentation (heat transfer boundary condition section):
Hope the above helps, |
June 23, 2014, 11:00 |
HH
Rep Power: 12 |
Dear Opaque,
Thank you very much for your response. |
June 27, 2014, 01:33 |
Marcin
Rep Power: 12 |
you can change from adiabatic to thin wall (with defined outside temperature and thermal conductivity if you know this values from your BCs).
June 27, 2014, 11:55 |
HH
Rep Power: 12 |
Thank you Martin_Sz. It is a good idea.
October 17, 2016, 07:59 |
#7 | |
Vijaya Kumar. G
Rep Power: 9 |
October 17, 2016, 17:39 |
Rep Power: 143 |
No idea. Try the openfoam forum.
natural convection | mehrdadeng | CFX | 10 | February 25, 2011 05:25 |
Wall radiation + Fluid reaction | Alberto Guerra | CFX | 1 | January 6, 2006 15:37 |
adiabatic wall boundary of conjugate heat transfer | tomosada | Siemens | 1 | May 13, 2005 00:14 |
Radiation problem with one wall | bkoh | Siemens | 2 | March 3, 2005 20:21 |
Radiation flux to the wall surface | Jason | Phoenics | 1 | May 26, 2004 01:13 |
