multiple fluid domain
Like Tree15Likes
  • 2 Post By Sumedh
  • 10 Post By Opaque
  • 3 Post By srinath_cfx
Old   April 28, 2007, 06:43
Default multiple fluid domain
Sumedh
In problems involving multiple fluid domains , if i define,for eg, air as the fluid in first domain and water as the fluid in the second domain, then automatically the fluid in the first domain changes to water.can anyone tell where the problem lies? Thanks in advance
sircorp and katty17 like this.
Old   April 28, 2007, 11:00
Default Re: multiple fluid domain
ParodDav
Hi, you should specify, when meshing your domains, two different materials. If the material in your mesh is same, you cannot specify two different materials. Which mesher do you use?
Ciao Davide
Old   April 28, 2007, 14:40
Opaque
Dear Sumedh,
By default ANSYS CFX-Pre keep the Fluids List within fluid domain the same on all the fluid domains. This is called "constant physics" for fluid domains.
However, if you want to have different materials for disconnected fluid domains, you can do that by disabling "constant physics".
In ANSYS CFX-11.0, you can do so by
1 - go to Edit/Option/CFX-Pre and check your settings.
2 - right click on Simulation Type, and I believe you can enable/disable it there as well.
3 - Use the old enviroment variable CFX_NO_CONSTANT_PHYSICS and set it to 1, or T
You can search for in the forum for similar postings as well.
Very IMPORTANT.. When constant physics is disabled, CFX-Pre no longer enforces that models are consistent for connected fluid domains. For example, if you change one fluid domain from Laminar to SST, you must manually fix all connected fluid domains; otherwise, the solver will fail with an obscure message. Opaque
Old   May 3, 2007, 05:14
sumedh
thanks a lot. I have made two different bodies in ICEM before meshing, the problem is coming in pre.
Old   May 3, 2007, 05:15
sumedh
Thanks a lot. I would try this out.This seems to be very helpful.
Old   April 2, 2013, 08:36
Post shock tube problem
srinath
srinath_cfx is on a distinguished road
I am running ANSYS CFX-13.0. In the CFX menu bar 'edit->options->CFX-pre->general', I have 'ticked' the 'enable beta physics' and 'un-ticked' the 'constant domain physics'.
For time being I have to run the shock tube problem for 2 different gases say helium (driver) and air (driven). How do I add the materials in CFX-pre? Is it a homogeneous mixture or a pure substance?
Thanks.
srinath_cfx is offline   Reply With Quote
Old   November 14, 2013, 10:58
Dimitris Romanas
Volumeoffluid is on a distinguished road
Originally Posted by ParodDav
;81323
Ciao Davide
how specify my materials before meshing???
i use DesignModeles, Ansys Meshing, Fluent Ansys 14.5
Thank you in advance!
Volumeoffluid is offline   Reply With Quote
Old   May 26, 2015, 03:22
Default Multi Fluid Domain
Dr Gurubasavaraju
gbrajtm is on a distinguished road
I was trying model the laminar flow analysis,
One Thin film region is Gas, another region is CO2, both are flowing in opposite direction, I am not able to specify the two materials for the respective two region. Could you help, how to do it. Attached fig
gbrajtm is offline   Reply With Quote
Old   May 26, 2015, 08:31
Opaque will become famous soon enough
http://www.cfd-online.com/Forums/cfx...-material.html
Opaque is offline   Reply With Quote
Old   December 14, 2016, 10:04
sunil kumar
skumar112 is on a distinguished road
;81323
Ciao Davide
Hello I am having the same problem on fluent using the meshing tool in Ansys Fluent 17.2
skumar112 is offline   Reply With Quote
Old   December 14, 2016, 16:36
Try the fluent forum.
Interface between fluid domain and porous domain windhair CFX 6 May 10, 2018 14:26
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Radiation at interface between fluid and porous domain Hitch8 CFX 19 April 20, 2015 06:24
Cross Flow cooling system involving multiple fluids and a solid domain ajaymenon CFX 4 March 8, 2012 17:00
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
