November 24, 2012, 09:29 |
PostGui_ogl.exe has stopped working
Meimei Wang
Rep Power: 15 |
Hi
When I open the CFX post, the error message is 'PostGui_ogl.exe has stopped working'. But i can run CFX-solver and open the CFX-Pre without any problem. May I ask how to solve this problem? Thank you very much!
Best regards, Meimei |
November 25, 2012, 04:07 |
Rep Power: 143 |
Some ideas:
* Try opening it from the launcher * Try oipening it from the command line * Open it from the command line using the -mesa option. This starts it up in a different graphics mode. |
November 25, 2012, 05:08 |
#3 | |
Meimei Wang
Rep Power: 15 |
Thanks. I have solved this problem by simply deleting the .cfx folder.
October 23, 2013, 11:34 |
pietro
Rep Power: 12 |
hi, I'm having the same problem with CFD-post 14.0 what do you mean with deleting the .cfx folder? did you delete the folder with the files that you where working on or something else ?
Fluent and workbench are working fine. the only problem is with Post. Any suggestions ? thanks |
October 23, 2013, 15:34 |
pietro
Rep Power: 12 |
sorry for asking, I've not been using ansys for long how can I open it using the mesa option?
October 23, 2013, 17:19 |
Rep Power: 143 |
Look in the documentation on starting CFX from the command line. the -mesa is a command line option.
October 24, 2013, 02:49 |
Lance
Rep Power: 22 |
I believe the correct command line argument is
-gr mesa or -graphics mesa |
October 24, 2013, 04:07 |
pietro
Rep Power: 12 |
I tried to open it from the command line, but the mesa option for graphics is only for linux systems apparently. The problem is still there. nothing changes if I use the launcher or the command line, I always get an error saying that "the program can't start because libCuEGuiViewer.dll is missing from your computer. Try reinstalling the program to fix this problem"
I also tried to reinstall the program but it didn't work. I still can't open the program. is the recovery my only option? since yesterday it was working fine |
October 24, 2013, 05:45 |
#9 |
Rep Power: 143 |
Try deleting the .cfx directory. This is a temporary directory which gets put in your local users temporary file path. For windows 7 that is C:\Users\<UserName>\.cfx by default.
October 27, 2013, 10:54 |
#10 |
pietro
Rep Power: 12 |
I found it and simply deleting the folder it started to work fine again.
thanks a lot |
February 8, 2015, 12:15 |
#11 |
Rep Power: 11 |
Hello
I begin with ANSYS, When I open the CFX post, the error message is 'PostGui_ogl.exe has stopped working'. I have delate .CFX folder but it doesn't solve the problem. I need your help. Thanks |
February 8, 2015, 17:07 |
#12 |
Rep Power: 143 |
This can happen if opengl is not working on your machine. If you are using linux try cfdpost -graphics mesa. If you are using windows check that opengl is working.
February 8, 2015, 20:31 |
#13 | |
Rep Power: 11 |
I use window 7 32bits with graphic card "ATI Mobility Radeon HD 4200" but i dont know how to verify if OpenGL is working. I have look every where and made researches with the word OpenGL but no response on my machine. How can i proceed?? Thanks!!! |
February 8, 2015, 21:25 |
#14 |
Rep Power: 143 |
Check the driver for your video card is up to date. Then look at the video card properties and check that the opengl options are enabled.
February 9, 2015, 10:15 |
#15 | |
Rep Power: 11 |
Otherwise, when i try CFX launcher directly the message is: " le point d'entrée de procedure ?detach3@QlistData@@QAEPAUData@1@XZ est introuvable dans la bibliothèque de liens dynamiques QtCore4.dll. " Thank you for help. |
February 9, 2015, 16:55 |
#16 |
Rep Power: 143 |
That looks like a Qt error. This looks pretty bad, something is very wrong with your installation. Have you removed CFX and reinstalled.
February 10, 2015, 13:09 |
#17 | |
ziad khan
Rep Power: 11 |
February 10, 2015, 13:10 |
#18 |
ziad khan
Rep Power: 11 |
m cheking the answers modes saying the quotes and without quotes
February 10, 2015, 16:28 |
#19 |
Rep Power: 143 |
The installation normally is simple.
Look in the installation manual to check you have the necessary pre-requisites. Follow the instructions and it should work. ANSYS support can help you if you still have problems. |
February 10, 2015, 20:00 |
#20 | |
Rep Power: 11 |
I have removed and reinstalled the software but it is the samething all other module run correctly, but when i try to launch the post by CFX launcher the message is: An error has occured in cfx5post : D:\Program Files\ANSYS Inc\v150\CFX\bin\winnt\PostGui_ogl.exe could not started, or exited with return code 255 : il n’y a plus de fichier. Otherwise when i execute InstallPreReqs.exe it says that no prerequis is necessary!! I think i will begin training with the first modules and see later with the cfx-post. Thank for all!!!! |
ANSYS program has stopped working? | chihoangkt | ANSYS | 0 | July 16, 2012 16:41 |
ParaView and Tecplot 360 'has stopped working' on windows | zhenglun.wei | OpenFOAM | 0 | June 27, 2011 17:29 |
ParaView and Tecplot 360 'has stopped working' on windows | zhenglun.wei | Main CFD Forum | 0 | June 27, 2011 11:49 |
ParaView Stopped Working | AlanR | OpenFOAM | 5 | April 17, 2010 04:55 |
OpenFOAM Message Board Email notification stopped working | mbeaudoin | OpenFOAM Bugs | 3 | January 8, 2009 22:08 |
