April 14, 2000, 14:24 |
simulation of boiler combustion
Hi, guys: Is anybody has experince on simulation of boiler combustion. Thanks xfshi
April 14, 2000, 20:39 |
Re: simulation of boiler combustion
In fact,It's very easy using cfx4.I think perhaps you are a beginner of CFX.If you are in China,you can connect with me directly. Best regards
Sincerely yours Li XInfeng |
May 11, 2000, 23:03 |
Hi,Mr.Li, I want to use CfX4.2 to calculate coal combustion in boiler furnace.What about your results of calculation? If possible,send me .geo and .fc Thank.
May 18, 2000, 09:11 |
Dear friends,
Incidently, I am working on boiler combustion modelling using CFX4.2. If you could send me a test case (*.fc,*.geo,*.f...), I would be very grateful to you. Thanking You Ayyapillai Murali |
July 14, 2000, 06:44 |
Re:Li XInfeng
Dear sir, I am working on coal furnaces modeling but I have some questions, would you mind if I ask you about my doubts directly to your e-mail?
July 15, 2000, 10:24 |
I can't send a email to you,your email address is not correct.
August 5, 2000, 05:31 |
i work about simulation furnace by cfd method. i want information about up topic. i wish you help me. thank.
October 23, 2000, 18:27 |
i am M.Sc student at t.m.u. i work about simulation pyrolysis heater using cfd models. i need some informations please i want ypur help. thanks
March 21, 2019, 04:51 |
shafqut hussain shah
Rep Power: 7 |
Dear all,
I am currently started studying CFD and i have a very basic question regarding heat transfer CFD. I am suppose to calculate the overall heat Flux through a modified Boiler pipe. when we calculate the heat flux we only consider energy transfer through convection? My question is that do we include radiation (in terms of internal emissivity ) while calculating over all heat Flux through a boiler pipe with Flue gas inside the boiler and tube surface temperature as 457 K. |
March 21, 2019, 05:49 |
Rep Power: 143 |
Whether radiation is important will depend on your exact application. if you want to be sure run a simulation with and without radiation and see what difference it makes.
March 24, 2019, 12:46 |
#11 | |
Rep Power: 7 |
Thank you for your reply! i am trying to simulate a dead end furness with inlet fuel as 100 % methane and oxydent as 23 % oxygen and 77 % nitrogen. My task is to evaluate the total amount of heat transfer through the surface of the furnace and heat transfer through the boiler tubes with different geometries. There is alot of difference in terms of total heat transfer through the surface when radiation is turned on but the energy balance is not valid for that case. I like to know how are these calculated 1) Internal emissivity of the Flue gas 2) absorption coefficient of the Flue gas 3) scattering coefficient of the Flue gas Any help highly be appreciated |
March 24, 2019, 17:05 |
#12 |
Rep Power: 143 |
Those parameters are all explained in the documentation. Have you read the CFX documentation?
Help regarding CFD simulation of boiler | ankit.mittal | ANSYS | 0 | June 3, 2010 08:53 |
Combustion SImulation in Fluent | santhosh1987 | FLUENT | 1 | May 14, 2010 16:03 |
Combustion SImulation in Fluent | santhosh1987 | FLUENT | 0 | May 14, 2010 10:32 |
Problem in solving combustion simulation | Ramesh | FLUENT | 0 | June 2, 2006 12:21 |
about simulation of Pulverised coal combustion | kris | Siemens | 0 | September 1, 2005 04:50 |
