isolated fluid regions were found in domain Default Domain-----ERROR |
February 15, 2017, 08:03 |
Nik Ferguson
Rep Power: 9 |
Hi everyone,
I have a problem and I don't know how to fix it. I have a fluid entering a circular tube and exiting on the other side. Inside the tube I put inserts to see if this has an effect on turbulence ect. When I try to run CFX-solver it breaks down before it starts. It says: "isolated fluid regions were found in domain Default Domain" I read somewhere that a solution could be to set the expert parameter "check isolated regions = f". I tried this and although the solver worked, it isn't a correct streamline in CFX-Post. I attached a photo so you can see what I mean. Does anyone know what to do? I would be extremely grateful. Nik Problem.PNG |
February 15, 2017, 10:52 |
Rep Power: 11 |
I think you are basically getting somewhere 2 separated domains and there is no interface linking them. So you have 2 separated fluid regions.
1) Remove the expert parameter. 2) Try to understand why CFX is identifying two separate fluid domains |
February 15, 2017, 11:41 |
Nik Ferguson
Rep Power: 9 |
Thanks highorder_cfd!
I tried the first step you mentioned and CFX-Solver just breaks down before the first iteration. As for step 2. That is exactly the part I do not understand. Do you have any suggestions on how to fix it? Thank you ! |
February 15, 2017, 11:45 |
Rep Power: 11 |
There is something basically wrong in your domains definition.
When you setup your default fluid domain in CFX, in the Basics Settings tab>Location and Type>Location> expand [...] and here you will display all the meshing parts which will be showed in the view window, so you can undestand if actually there is a separate fluid region in your case. |
February 16, 2017, 15:03 |
#5 | |
Rep Power: 12 |
February 21, 2017, 07:14 |
Nik Ferguson
Rep Power: 9 |
Thank you very much for your reply.
Can you tell me where I can check if the automatic interface creation is activated or not? Thanks a lot! |
February 21, 2017, 07:26 |
Nik Ferguson
Rep Power: 9 |
I found out where to check the setting. It was activated. I deactivated it and it would complete "normally" before completing the first iteration and it did not produce results.
February 21, 2017, 09:15 |
Daniel
Rep Power: 9 |
Is it an option to make a Fluid Domain and than a Solid Domain with the inner parts? Then maybe a few interfaces of Fluid/Solid...
CFX will usually create automatic interfaces so u can delete them If u think they are wrong and than create your domains with the interfaces |
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 05:59 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
Undeclared Identifier Errof UDF | SteveGoat | Fluent UDF and Scheme Programming | 7 | October 15, 2014 07:11 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
