October 21, 2000, 11:02 |
Supersonic Flow setting
Hi, I am trying to test a supersonic flow in a simple divergent duct. Is it possible to set velocity inlets or does it have to be pressure inlets?. Something else, any advice about setting the reference pressure on CFX? Thanks for your time.
October 23, 2000, 01:25 |
Re: Supersonic Flow setting
you can set velocity in the inlet instead of pressure inlet... the way to set the flow to be supersonic is to choose 'total energy' option instead of 'thermal energy' when setting up the fluid model.
Modifying the "Transonic Flow over an Airfoil" tutorial for supersonic flow? | darrenn | STAR-CCM+ | 3 | November 15, 2021 16:52 |
back pressure at exit for supersonic flow | BigFrank | FLUENT | 6 | April 24, 2014 15:13 |
Liquid Jet into Supersonic Flow | Alex | CFX | 4 | June 20, 2007 10:56 |
Modeling Bleed in Supersonic Flow | Mohd Yousuf Ali | FLUENT | 0 | March 17, 2007 03:51 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
