Cannot change Specific Heat Capacity option to NASA polynomials in CFX 14.5.7 |
March 11, 2017, 03:42 |
khedar
Rep Power: 9 |
Hi, I need to use temperature dependent Cp(specific heat capacity) for my simulation. But in the material properties, the only option I get is "Value". I read the modelling guide and it says that there should be other options as well. Is this some version issue?
Thanks |
March 13, 2017, 09:36 |
Rep Power: 11 |
Can you not set an expression there?
March 13, 2017, 12:06 |
Rep Power: 32 |
If I recall correctly, the NASA and/or Zero Pressure Polynomials options are ONLY allowed for ideal gas materials.
Is you equation of state Ideal Gar, or constant density material ? |
March 15, 2017, 08:43 |
khedar
Rep Power: 9 |
I am using ideal gas but still cannot see the option. Finally I did using expressions. Thanks guys for the help
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
