April 7, 2011, 20:13 |
How to measure the dynamic pressure?
Kooky
Rep Power: 15 |
Dear All,
I have a question of how to measure the dynamic pressure in CFX post. Thank you for your answer. |
April 7, 2011, 21:38 |
Bharath kumar
Rep Power: 17 |
Hi kiat,
make an expression like dyn = 0.5*rho*V^2 (or) dyn=total pressure- static pressure then assign a variable like Dynamic pressure to the expression you created in post and plot the contour now. |
April 8, 2011, 11:07 |
Kooky
Rep Power: 15 |
April 10, 2011, 09:44 |
Kooky
Rep Power: 15 |
Dear All,
I was applying the boundary condition, the mass flow rate at the inlet surface and static pressure is zero at the outlet surface. So, I was checking the static pressure at the outlet surface in CFX post, it did not the same value. Anybody knows how to obtain the same value. [Total pressure is sum of static and dynamic pressure. I measured the total pressure and dynamic pressure at the outlet surface.] Thank you for your respond. |
March 22, 2017, 03:12 |
something wrong with my dynamic pressure
Qiong-yao Wang
Rep Power: 12 |
Thanks for your advice, but my dynamic pressure reached to 1.5e31 according to your advice. Can you explain that? thanks!!
March 22, 2017, 05:54 |
Rep Power: 143 |
Your simulation has diverged. You are just about to get an overflow error, which means this FAQ is relevant: https://www.cfd-online.com/Wiki/Ansy...do_about_it.3F
Maintaining Static Pressure at Fluid Flow Inlet | cdevalve | FLUENT | 3 | January 14, 2012 00:11 |
Pressure Rise Error | emueller | CFX | 0 | May 5, 2009 11:08 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
Dynamic pressure at stag point for 3d aerofoil | Matt | FLUENT | 3 | January 30, 2006 19:31 |
pressure measure in centrifugal pump vanes | Patricio Torrejon | FLUENT | 1 | December 16, 2005 17:10 |
