Centrifugal compressor impeller+vanless diffuser simulation problem. |
March 22, 2017, 11:36 |
MaoZhiming
Rep Power: 9 |
Hi to All
I'm doing the steady state analysis of an Centrifugal compressor with vaneless diffuser. I've done the simulation with solving the entire domain in rotating reference frame and set the shroud and hub of diffuser as counter rotating wall. Here my problem is, the results indicated that the Total Temperature and enthalpy decrease form the impeller TE Cut to the diffuser outlet, the Tt difference is above 5K. And since the Tt decrease, the polytropic efficiency of impeller &diffuser is even higher than the impeller alone. So the results is definitely inaccurate. The turbulence model is SST and wall yplus is around 3. Inlet boundary is Pt and Tt, Outlet boundary is average static pressure(results of mass flow rate outlet still have the problem).Alternate Rotating Model is on. I have change the grid and turbulence model, but the phenomenon still exist. I'm stuck here several weeks, wish somebody can help me. Any suggestion? Thank you~ |
March 22, 2017, 15:00 |
Have a nice time!
Rep Power: 11 |
Hello, Do you use TurboGrid and CFX?
Thanks |
March 22, 2017, 19:37 |
MaoZhiming
Rep Power: 9 |
March 22, 2017, 20:01 |
Have a nice time!
Rep Power: 11 |
I have tutorials about a radial turbine..I am not sure if they will help you or not..but you can contact me on 12317@eng.asu.edu.eg to send me the details of your problem...Thanks
March 24, 2017, 12:27 |
#5 | |
March 26, 2017, 22:10 |
Tony
Rep Power: 10 |
Have you tried KE model? What turbulence model have you tried? How is the setup of heat transfer? Are you using the option of Total Energy?
March 27, 2017, 12:16 |
MaoZhiming
Rep Power: 9 |
March 27, 2017, 19:12 |
Try (R1+S1) domains with the impeller rotating up to an immediate downstream of the trailing edge. What you simulated is "the rotating diffuser" case.
centrifugal compressor, vaneless diffuser |
Pressure dissipation problem in bubble simulation (Riemann problem) | ndabir | CFX | 9 | June 4, 2015 16:48 |
SIG Turbo ERCOFTAC Centrifugal Pump - OF Revision Problem? | marcelgt87 | OpenFOAM | 18 | June 26, 2012 08:59 |
[CFX] Simulation of Flow Separation in a rectangular diffuser - Convergence Problem | anon_b | CFX | 11 | May 6, 2012 20:16 |
Urgent problem! Appreciate all you help!! 3D Centrifugal Pump set up problems! | RR2 | FLUENT | 5 | April 13, 2012 08:17 |
Large-scale simulation problem | Purushothama | Main CFD Forum | 0 | November 7, 2010 20:12 |
