Q:Vane initial field with tascflow.
Old   June 14, 2001, 10:05
Default Q:Vane initial field with tascflow.
lhb
Every specialist: I tried many times and couldn't get a convergent result when I calculate just one row of turbine vane with tascflow. I used pressure inlet condition and pressure outlet condition, the outlet Mach number should be 1.05 if it's convergent. How should I set up this problem?
thanks advance.
Old   June 14, 2001, 11:39
Default Re: Q:Vane initial field with tascflow.
John C. Chien
(1). Try to lower your exit Mach number first. (2). Run another case, to see whether you can get the flow field to converge at a lower Mach number. (3). If you still have problem, check with the support engineer.
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
