Request steps for aeration pattern study in steady water tank |
March 29, 2017, 10:50 |
Hi guys, can anyone help me in aeration pattern study in open water tank? The water is in steady state and the air is flowing from bottom to top of the tank. I can't find any tutorials for this. I tried many times in Ansys CFX but failed.
March 29, 2017, 17:26 |
Rep Power: 143 |
There is an example on the ANSYS customer webpage of exactly this. Look for "Chapter 18: Gas-Liquid Flow in an Airlift Reactor"
March 29, 2017, 22:02 |
Thank you so much ghorrocks. I tried the steps stated in it. That one only one inlet. I have 24 diffusers define as one inlet. So i need to define the inlet velocity as 0.3 m/s (per diffusers) or I need to multiply the value by 24? At inlet, the volume fraction of air is one and water should be zero right?
March 29, 2017, 23:24 |
Rep Power: 143 |
You have to make sure you get the correct air flow rate on the boundary. So if you are defining it by inlet velocity then you have to make sure your modelled inlet area * inlet velocity is the correct air flow rate.
March 30, 2017, 01:01 |
I have tried with mass flow rate. Amount air coming out of the inlets are not uniform. Why am I facing this problem? Is this because of meshing? At outlet the air flowing into the domain.
No liquid water exist in my Fuel Cell simulation | fatchang | FLUENT | 19 | October 15, 2018 14:27 |
Setting Up a case on building an empty tank with water going into the tank | Nori4U | OpenFOAM Programming & Development | 1 | May 8, 2015 02:10 |
CFX / buoyancy/mixing of water in tank | Christos lorakis | CFX | 5 | November 30, 2003 16:32 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
