January 15, 2014, 21:09 |
CFX Multicores Computing
david
Rep Power: 13 |
Can somebody be kind enough to explain to me the difference between platform mpi local parallel and intel mpi local parallel?
Many thanks in advance |
January 17, 2014, 02:37 |
#2 | |
Rep Power: 18 |
But I have problems with using Platform MPI on Supermicro server with Windows Server 2008 r2 (mpid.exe crashes) while Intel MPI works well. |
April 1, 2014, 04:29 |
Neal
Antanas,
Did you got solution for mpid.exe, because currently I am facing same issue on Ansys 15.0. I am using windows 7. Regards |
April 1, 2014, 04:52 |
Rep Power: 18 |
April 1, 2014, 04:56 |
Neal
Antanas,
Actually I have two machines both with Win 7. On old machine its working with MPI, but I face problem with new machine. |
April 1, 2014, 05:18 |
Rep Power: 18 |
Then find main differences between 'em (hardware + software) and it may give you a cause. Maybe there is a software that interfere or conversely you missed something.
April 1, 2014, 07:14 |
Erik
Rep Power: 23 |
Platform MPI should work fine with windows 7, I'm guessing there is a firewall issue with the one computer that isn't working. You may have to open the MPI port in the firewall:
Also add firewall exceptions for MPI: On the Windows Firewall dialog box, click the Exceptions tab and then click Add Program. Browse to the following programs: • For Platform MPI: – <ANSYS Inc installation path>\v150\CFX\bin\<CFX5OS>\solver-pcmpi.exe – <ANSYS Inc installation path>\v150\CFX\bin\<CFX5OS>\double\solverpcmpi.exe – <ANSYS Inc installationpath>\v150\commonfiles\MPI\Platform\<v ersion number>\winx64\sbin\pcmpiwin32service.exe – <ANSYS Inc installation path>\v150\commonfiles\MPI\Platform\<version number>\winx64\bin\mpirun.exe – <ANSYS Inc installation path>\v150\commonfiles\MPI\Platform\<version number>\winx64\bin\mpid.exe Did you install platform MPI? Have you run the MPI test program? Local MPI Test: Make a folder called "temp" in c:, it may already exist. Run the following command in cmd: Change to c: then type: cd\temp. Then Type: "C:\Program Files\ANSYS Inc\v150\ansys\bin\winx64\ansys150.exe" -np 2 -mpitest Like I said, you may have to open the MPI port in the firewall for both inbound and outbound traffic. |
April 1, 2014, 11:05 |
#8 | |
Rep Power: 18 |
April 2, 2014, 06:10 |
#9 |
Neal
I have installed platform & also added above mentioned exe in firewall.
Still problem persist. |
April 2, 2014, 21:01 |
#10 |
Erik
Rep Power: 23 |
What is the problem? Can you be more specific? Did you run MPI test? Is the MPI service running?
March 31, 2017, 19:13 |
Intel is better
#11 |
Rep Power: 11 |
The way Platform MPI starts in startmethods.ccl uses some type of process pinning that doesn't work with larger Intel v3 processors. You need to delete affwidth and affcycle.
With v17 Intel MPI works much faster anyways on our cluster. |
CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 07:08 |
Different flow pattern between OpenFOAM and CFX | AirS | OpenFOAM | 0 | January 12, 2010 07:08 |
heat generation in CFX | Ema | CFX | 4 | August 7, 2009 05:39 |
CFX 10's solutions differ from CFX 5.7's | Atit Koonsrisuk | CFX | 4 | July 26, 2006 11:59 |
CFX distributed computing: Cluster design Q | Joe | CFX | 7 | July 11, 2006 10:21 |
