How to make Nussel Number Contours in ANSYS CFX? |
October 25, 2020, 04:10 |
Ali M
Rep Power: 5 |
Hi Everyone
I am working on Gas Turbine Blade. I want to know that how to make Nusselt Number Contours in CFX Post. Thanks |
October 25, 2020, 17:12 |
Rep Power: 143 |
Define a user variable (Variables tab, right click "New") and define a CEL expression which gives your definition of Nusselt Number. It will then appear as a variable which can be used for contours, streamlines, isosurfaces and all the other functions.
Note that Nusselt number takes the heat transfer at a boundary, so it is only defined at a boundary. This means only post-processing objects which work on boundary surfaces will be able to show it, such as contours. Post processing objects which work on the 3D domain (such as streamlines or cross section planes) will not show it.
October 29, 2020, 08:07 |
Ali M
Rep Power: 5 |
Thank you for your reply.
I have a problem when I create the expression then there is some kind of error shown that is "Reference error". How to create reference in ANSYS CFX? Regards |
October 29, 2020, 08:49 |
Gert-Jan
Rep Power: 27 |
This doesn't ring a bell.
Where did the error occur? In Pre? Then cut and paste the error here, or make a screenshot. |
November 2, 2020, 02:29 |
Ali M
Rep Power: 5 |
In my case, there is a hot domain, cold domain, and Aluminum solid blade.
Hot Fluid Temperature is 296K Cold Fluid Temperature is 296K Internal Surface Heat Flux is 2000(W/m2-K) |
November 2, 2020, 02:34 |
Gert-Jan
Rep Power: 27 |
This has nothing to do with 'reference'.
In your Nu-equations, you use the term 'Twall'. But since you haven't defined what Twall is, CFX gives this error. Probably you need to define something like: Twall = areaAve(T)@Wall |
November 2, 2020, 02:47 |
Ali M
Rep Power: 5 |
The temperature of the wall is defined as automatic in CFX Pre.
November 2, 2020, 02:58 |
Ali M
Rep Power: 5 |
Same error again.
I want to know that is there any line or point to define this reference on the blade surface? And how to define this? |
November 2, 2020, 03:11 |
#9 |
Gert-Jan
Rep Power: 27 |
You should do some more tutorials since you are missing some basic knowledge of CFX.
November 2, 2020, 03:13 |
#10 |
Gert-Jan
Rep Power: 27 |
November 3, 2020, 07:46 |
#11 |
Ali M
Rep Power: 5 |
Thank you for your guidance. The issue is resolved but I want to create Nusselt Number Contours as shown in the attached picture.
How to make Nusselt number contour on the curve body? |
November 3, 2020, 16:37 |
#12 |
Rep Power: 143 |
You should do the CFX tutorials. This is a really basic question.
You just define a contour object and define the surface you want as the location.
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 09:23 |
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' | BrendaEM | OpenFOAM Meshing & Mesh Conversion | 12 | April 3, 2022 18:32 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
