August 27, 2001, 05:11 |
External flow
Hi Friends,
I am trying to modell an external flow, flow over a cyclist helmet. But on CFX 4.3, every example is done for internal flows, like pipe, and furnance models. I created the geometry file successfully, how can i drive air on tha helmet? Do you think CFX4.3 does not work for external flows??? Tadiwos |
August 28, 2001, 01:11 |
Re: External flow
CFX-4 can certainly do external flows. What exactly is the problem you are having? i.e., you can't figure out how to set it up in CFX-4, the solver doesn't run and crashes, etc..?
August 28, 2001, 03:07 |
Re: External flow
(1). If you are solving flow over a sphere, you would create a box, a sphere, and then generate the mesh between the sphere and the box boundary. This becomes your computational domain. (2). Then you can specify the inlet condition on the box boundary, the far-field boundary conditions on surrounding walls, and the exit condition on the downstream wall. On the sphere, you will have to specify the wall condition. That's all. (3). Now replace the sphere by your helmet model. The process is identical. (4). This also can be used for flow through a pipe, where the helmet has zero size (removed from the computational domain), and the box is now made to fit the pipe shape. And the box wall boundary condition will be real wall (now the pipe walls). (5). It up to you to look at the problem, you can make it either internal flow or external flow.
External 3D flow using k-ω | Leonpolou | Main CFD Forum | 0 | March 24, 2011 20:37 |
Modeling internal and external flow for a nozzle | smschnob | Main CFD Forum | 1 | November 11, 2010 17:12 |
Boundaries in external flow | crzbur | FloEFD, FloWorks & FloTHERM | 10 | August 19, 2009 15:06 |
[Salome] Salome-OpenFOAM external flow (around a ship) | tomislav_maric | OpenFOAM Meshing & Mesh Conversion | 34 | August 13, 2009 09:30 |
Why Re is different for external and internal flow | john | CFX | 3 | June 13, 2007 22:31 |
