April 21, 2017, 14:19 |
Material definition in ANSYS CFX
Vishal Chauhan
Rep Power: 14 |
I am trying to simulate a heat transfer problem and for that I need to define material in Material tab of ANSYS CFX PRE. The problem what I am facing now is like this. When I define material in Material tab with its properties it works fine, but when I open domain tab and try to allocate defined material to newly created domain then its not in the list of material library. I have tried a lot many times even to redefine the material but did not work at all. |
April 24, 2017, 15:29 |
Erik
Rep Power: 23 |
Did you pick the right domain type? Solid vs Fluid?
April 24, 2017, 23:53 |
Rep Power: 32 |
Check the Thermodynamic State is compatible with the domain type you are using. Alternatively, you can unset the Thermodynamic State and it should work with any domain.
April 25, 2017, 03:21 |
#4 | |
Vishal Chauhan
Rep Power: 14 |
Btw thanks for your reply. Sent from my Hol-U19 using CFD Online Forum mobile app |
April 25, 2017, 03:22 |
Vishal Chauhan
Rep Power: 14 |
Yes my domain is solid and I have selected solid domain in tab.
material in cfx pre |
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 04:28 |
CFX FSI Fatal Error | unbanana | CFX | 0 | October 3, 2015 05:57 |
I got code 1 error from ANSYS CFX | zlor1324 | CFX | 0 | March 11, 2014 19:22 |
Cfx aborted due to unknown errors | AKHILESH S L | CFX | 2 | October 10, 2013 17:16 |
CFX bought by Ansys - good or bad?! | Pete | CFX | 38 | February 21, 2003 07:34 |
